Browse Forums Building A New House Re: Storage in your roof??? 11Jan 10, 2008 1:01 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Storage in your roof??? 15Jan 10, 2008 10:00 pm I'm with Michelle.
A great deal depends on whom you build with (volume builder or private) and their supplier. You need to ask your builder what live load the trusses can handle. Due to the cost effectiveness of volume builders, the trusses can sometimes be comped up to suit 100 - 150kg live loads only which can have a higher fail rate. For example - if you are having a cooler or central heater, look at the trusses where the units are to be placed (at frame stage), the bottom chords of the trusses should be heavier (there are usually 3 to 4 trusses in total - all together) tan the common trusses - these are trusses that have been comped up to suit additional weight. H 2 9458 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4224 |
