Browse Forums Building A New House Re: gutters/fascia/downpipes - colorbond or zinc aluminium 2May 05, 2011 5:52 pm Well I payed $1800 to go to colorbond gutters, fascia and downpipes! So I'd jump at $750! Think of it this way, it will cost probably cost you more than that the first time you have to paint them if you go for zincalume. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: gutters/fascia/downpipes - colorbond or zinc aluminium 4May 05, 2011 8:15 pm joles Well I payed $1800 to go to colorbond gutters, fascia and downpipes! So I'd jump at $750! Think of it this way, it will cost probably cost you more than that the first time you have to paint them if you go for zincalume. first time the builder is painting them any way. Re: gutters/fascia/downpipes - colorbond or zinc aluminium 5May 05, 2011 8:28 pm CC101 first time the builder is painting them any way. yes but they have to be painted regularly as partof their maintenance otherwise they look terrible. Colorbond may fade a little but you'll never have to paint it! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: gutters/fascia/downpipes - colorbond or zinc aluminium 6May 05, 2011 8:35 pm donuts CC101 first time the builder is painting them any way. yes but they have to be painted regularly as partof their maintenance otherwise they look terrible. Colorbond may fade a little but you'll never have to paint it! tell me if i am wrong. they say that once zinc aluminium is painted, it does not need to be painted for 10 years or so. and when you paint them, it looks like new again. But with colorbond, it looks definetly better in the begining but it gets faded after some time and you can not even pain that. Is that ture or i am of wrong opinion. Re: gutters/fascia/downpipes - colorbond or zinc aluminium 8May 06, 2011 9:26 am zincalum HAS to be prepared correctly before painting. It is usually coated in a fine oil to protect it from rusting before being installed. This has to be removed correctly before painting. Since it is installed first and then painted, the fascia and gutter not exposed after installation (ie top of fascia and bottom of gutter) cannot be painted and is then a 'weakspot' for corrosion. We had zincalum on previous house. The original paint faded, went powdery (it was a very light colour anyway) and peeled after 4 years and because of the bad prep work, the bottom of some of the guttering rusted out. Repainting was a nightmare because it had to be stripped right back to bare metal and primed and painted correctly. Go colourbond. Hi, I have an area of zincalume cladding encasing a number of external downpipes. Unfortunately one of them has been permanently stained by some diluted phosphoric acid -… 0 927 Devkop The good news it is super easy to fix. Just get your plumber to divert it to the other side of the window. But for those people who are wondering what the… 2 1729 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10294 |
