Here is my plan and front view.
http://i1179.photobucket.com/albums/x381/whoop1968/Plan.jpg
http://i1179.photobucket.com/albums/x381/whoop1968/Front.jpg
Browse Forums Building A New House 1 May 03, 2011 2:54 pm Here is my plan and front view. http://i1179.photobucket.com/albums/x381/whoop1968/Plan.jpg http://i1179.photobucket.com/albums/x381/whoop1968/Front.jpg Re: My custom build 3May 03, 2011 6:59 pm My 2 cents... I would probably modify the design like this if I was building this kinda house - Add space for a small ensuite to bed 1 by shifting bed 1 into the verandah area a bit but not intruding on light entering kitchen, also need to shift wall out of WIR a bit and recentre windows onto verandah. Maybe have a sliding door on the ensuite. - Add door from Garage 1 direct into house.. Like this (kinda d.o.d.g.y 2min job i did in mspaint but you get the idea). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I suspect you have narrow block and building footprints issues to deal with but I think if there is any way you can add an ensuite - even if small by modern home standards you should do it. Not sure I could cope living in a house with only 1 WC.... Re: My custom build 4May 04, 2011 12:03 am whoop1968 That is an interesting floor plan you have there. But to fully understand it I would like a little more information on the site size, boundary locations, aspects and family size/type. Initially I do not understand the planning. Im also interested to see the other materials you are planning to use as I can see you have noted flexicoat for the floor I will ask the questions for you to consider and answer. This based on the fact I know nothing of the points noted above. 1. Why don’t the garages connect into the interior of the house, at least one side? 2. For a small plan why have you divided the space with the wall between the kitchen and the lounge? 3. Why is there circulation space down both sides of the lounge space? 4. Why doesn’t the sitting room open off the entry? This will allow you to increase the width of the lounge and connect it to the outdoor space. Add the 5.7sqm of wasted corridor to the living space. 5. IF the site boundaries are very close to the building line, why have you divided the outdoor spaces into smaller disconnected spaces? 6. If you are trying to create natural cross ventilation it will work, but you could move the body of the house across to increase the open space to one side. 7. I am not commenting on the bathroom as I see it has been reviewed already in the main custom design thread.. I look forward to your response. My custom build 5May 04, 2011 7:07 am Not every one wants or needs an ensuite people. Our parents probably did without one for a fair amount if their lives. In saying that if it is a family home then I would look at adding a second toilet somewhere - even in a corner of a garage. The only other thing I would say is to access your garages internally. They both have access to hallways so it makes it much easier to have a door straight to the inside. Very interesting design. We are working an a site up front at the moment which only allows us 11m max frontage. My inlaws have managed to design a pretty huge house - but it is close to 35m in length which helps. Some things are worth waiting for. Re: My custom build 6May 04, 2011 8:16 am david242gt whoop1968 That is an interesting floor plan you have there. But to fully understand it I would like a little more information on the site size, boundary locations, aspects and family size/type. Initially I do not understand the planning. Im also interested to see the other materials you are planning to use as I can see you have noted flexicoat for the floor I will ask the questions for you to consider and answer. This based on the fact I know nothing of the points noted above. 1. Why don’t the garages connect into the interior of the house, at least one side? 2. For a small plan why have you divided the space with the wall between the kitchen and the lounge? 3. Why is there circulation space down both sides of the lounge space? 4. Why doesn’t the sitting room open off the entry? This will allow you to increase the width of the lounge and connect it to the outdoor space. Add the 5.7sqm of wasted corridor to the living space. 5. IF the site boundaries are very close to the building line, why have you divided the outdoor spaces into smaller disconnected spaces? 6. If you are trying to create natural cross ventilation it will work, but you could move the body of the house across to increase the open space to one side. 7. I am not commenting on the bathroom as I see it has been reviewed already in the main custom design thread.. I look forward to your response. Thanks for looking at my post. Site size is 16 meter frontage and 39 meters depth. 2 Adults no children. Backyard will be fruit trees and vegie gardens. 1. I am thinking of direct access from one of the garages. 2. That is what I like to seperate the kitchen area from the lounge. 3. The plan is to have setting areas looking out to the 2 outdoor areas. 4. The setting room will most likely become a movie room. 5. One out space will be undercover with a gas log fire the other has not cover which will be a court yard with water features. 6. I am trying to create cross ventilation and bring the outdoors in. Re: My custom build 7May 04, 2011 3:18 pm interesting floor plan, nice to see something a bit different to the 'norm' Re: My custom build 8May 04, 2011 4:33 pm I'd get the gutters to match your roof and pipes to match the paint - otherwise they become a feature. Nice pick with the paint colours! 1 34308 6 55397 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27952 |
