Browse Forums Building A New House 1 May 02, 2011 1:55 pm Hi, I brought a Land In Hibiscus 2 ( the Ponds) and the draft contour plans provided by Ponds has 1 metre fall, whereas when we did the site survey by the builder the contour plan says it has around 2.5m fall from Back Left to Front Right side(Opposite direction). Can anyone help me if you guys have huge fall around (2.5m) in the contour plan or do you guys noticed huge differences in contour plans in The Ponds. Cheers Re: Contour plan issues after site Survey in Hibiscus 2 2May 04, 2011 6:43 am IMO 2.5m fall on a block isn't a big problem, we are on a site wihch has 19.0m over 30.0m. Use the fall to your advantage when designing not only your house but garden. If you need retaining walls in the rear try to have the footings excavated and poured before the house is constructed Landscape Design & Construction http://cherub.squarespace.com/ Give "Holt Surveying" they are based around Eight Mile Plains 3 8739 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223606 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 |
