Browse Forums Building A New House Re: PV solar panels - which side of the house? 2Apr 28, 2011 1:17 am This link will give you some idea of efficiency for different panel orientation. http://www.anewhouse.com.au/?p=439 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: PV solar panels - which side of the house? 4Apr 29, 2011 10:46 pm We have most of ours around the solar hot water panels, on the north side main roof part (18), we could of fitted another 6 on that roof but as we had 27 in total they did 9 on the other part of our north facing roof which was shaded the last 30 mins of the day. (5KW system) So depending on the size of the system you could do both on the North side and having them coexist. If I was to win Lotto, I would build with a different builder, now to win lotto Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12284 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4674 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9231 |
