Browse Forums Building A New House Re: Choosing a Plan and Builder in WA - Advice Needed 2Apr 26, 2011 7:56 pm Jason Building a modified Platinum MKII with Blueprint Homes. House Plan Contracts Signed: 18/10/2010 Prestart 21/10/2010 Sandpad: 14/1/2011 Slabbed: 27/1/2011 Brickwork: 15/2/2011 Roof: 18/3/2011 Re: Choosing a Plan and Builder in WA - Advice Needed 4Apr 26, 2011 9:37 pm jbyway Celebrations build was quicker but they did have a lot of stuff ups (wrong roof tiles were installed and had to be changed). Don't like the sound of that!! Thanks for your feedback Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20417 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17949 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
