Browse Forums Building A New House 1 Apr 25, 2011 12:29 pm Can anyone let me know problems with recessing the aluminium tracks of stacker doors, into the slab so it doesnt protrude above the tile height, so no step up to get out? and secondly is there an issue with having the alfresco tiles then the same height as the inside tiles, so a smooth flow inside to outside? We specified this with our builder (and as everything they said 'no probs' in typical salesman fashion) with our plans stating 'track recessed into concrete'. But now the slab is down it looks like they are not meeting our expectaions, with the slab just showing a step down to the alfresco. It is a 5x7 two sided alfresco area facing northwest that seems to be reasonably sheltered. We plan to tile inside and out the same colour (polished in, rough out) and the stackers are 3.6 wide x 2.4. I would like the side pull flyscreens that roll out, and need to find out more about the tracks these use, and how the 'roll' is located. Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: Recessed tracks for stackers leading to alfresco. 2Apr 25, 2011 1:25 pm Hi There are a couple of issues...
If you recess the door, then make sure they order one a little taller as you need the head to align with windows. Flyscreens... the tracked ones work best - our door takes those. The cassette type will be damaged by young children and pets in no time - and they tend to blow in with the wind. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Recessed tracks for stackers leading to alfresco. 3Apr 25, 2011 1:59 pm Thanks Ed, Do the tracked retractable flyscreen use a track that is part of the stackers track? or an add on? If part of the stacker extrusion will this be 3 panes of glass width + one fly screen track? ,or is it required to be 3 + 2 flyscreen tracks? Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: Recessed tracks for stackers leading to alfresco. 4Apr 25, 2011 2:08 pm HI The retractable screens are a complete unit. They cover a wide area, and are quite weak and susceptible to damage IMO. The integrated flyscreen tracks stack the same as your stacker door, they use 2 extra tracks. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3950 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4168 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4843 |
