Browse Forums Building A New House 1 Apr 24, 2011 10:06 am G'day, Any opinions on Independant Building inspectors? Is it necessary to employ one? At what build stage would it be best? Shouldn't we trust the Inspectors that are employed by the Builders? Any opinions or experience out there? Cheers G Ger Re: Independant Building Inspectors??? 2Apr 24, 2011 10:29 am Hi, I am planning to use a building inspector for three inspections throughout my build (framing, pre-plaster and final inspection). My reasons for deciding to use a building inspector are: - I have no building knowledge, would not understand if there were problems with the frame, if things did not meet building standards - I have no friends or relatives with the building knowledge that I could ask instead of using an inspector - Considering the cost of the home, the expense of an inspection is not great in the overall budget to build a home - I would prefer to know if there were issues with the house at an earlier stage when it could be easily corrected rather than finding issues down the track after warranty has expired It depends on how many inspections the builders actually do (and how detailed they check). Quite often the builders will not give you a copy of the reports so you have no idea if they have picked anything up or how detailed the check was. Good luck, Michelle House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: Independant Building Inspectors??? 3Apr 24, 2011 11:15 am No, it is not compulsory to employ one but if anything, an independent building inspector will give you peace of mind - consider them double checking the work of the builder's inspector. As BW said, usually independent inspections are done on frame, pre-plaster and final - though you can always go for more if you're not too trusting of the works carried out, or if you're a bit iffy about some workmanship issues. The builders assure you that their inspectors are independent, but I personally wouldn't be trusting that they'd pick out -every- small minor detail. Nevertheless, you can always ask the builder to give you a copy of all inspections completed (and all the paperwork associated with the building of the house - you have a right to a copy of these papers as well). Re: Independant Building Inspectors??? 4Apr 24, 2011 7:12 pm buildingwest Hi, I am planning to use a building inspector for three inspections throughout my build (framing, pre-plaster and final inspection). My reasons for deciding to use a building inspector are: - I have no building knowledge, would not understand if there were problems with the frame, if things did not meet building standards - I have no friends or relatives with the building knowledge that I could ask instead of using an inspector - Considering the cost of the home, the expense of an inspection is not great in the overall budget to build a home - I would prefer to know if there were issues with the house at an earlier stage when it could be easily corrected rather than finding issues down the track after warranty has expired It depends on how many inspections the builders actually do (and how detailed they check). Quite often the builders will not give you a copy of the reports so you have no idea if they have picked anything up or how detailed the check was. Good luck, Michelle Thanks Michelle all good points and many thanks for taking the time to offer some feedback. Regards G Ger Re: Independant Building Inspectors??? 5Apr 24, 2011 7:14 pm We will be getting 2 independant inspections done. One before the internal linings go on and the other just before PCI. You can see more responses here viewtopic.php?f=31&t=43678 "I would never expect anyone to do something that I would not do myself" http://www.squeakbuilds.blogspot.com Custom Designer home. - Builder to be determined Re: Independant Building Inspectors??? 6Apr 24, 2011 7:16 pm irkj No, it is not compulsory to employ one but if anything, an independent building inspector will give you peace of mind - consider them double checking the work of the builder's inspector. As BW said, usually independent inspections are done on frame, pre-plaster and final - though you can always go for more if you're not too trusting of the works carried out, or if you're a bit iffy about some workmanship issues. The builders assure you that their inspectors are independent, but I personally wouldn't be trusting that they'd pick out -every- small minor detail. Nevertheless, you can always ask the builder to give you a copy of all inspections completed (and all the paperwork associated with the building of the house - you have a right to a copy of these papers as well). Thanks irkj, i agree, that extra piece of mind would make all the differance,. Thanks for taking the time and offering your thoughts Regards G Ger Re: Independant Building Inspectors??? 7Apr 25, 2011 7:51 am where did people find their inspectors, were they listed in the yellow pages Building NBG Buckingham 46 on Property in rural Victoria my Building Thread viewtopic.php?f=31&t=46837 Re: Independant Building Inspectors??? 8Apr 25, 2011 3:03 pm We will definatley be getting one. We have never built and I'm not cluey on all the ins & outs... I think we have to keep the builders honest!!!!! Re: Independant Building Inspectors??? 9Apr 25, 2011 9:58 pm equineaffair where did people find their inspectors, were they listed in the yellow pages I found the inspector I used last time and will be using in my new build from reading comments from people here on the forums. House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81896 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 2943 |
