Browse Forums Building A New House 1 Apr 20, 2011 4:07 pm Hi Everyone, what are some of the things I should be looking for during my PCI which is approaching? Should internal doors be painted on the tops and bottoms? Where should I be looking? What are some well known problems? Your experience is appreciated. Re: What to look for at PCI ? 2Apr 20, 2011 4:55 pm Hmmm... I was going to say do a search because there are a few threads on this floating around.... but there were no results when I searched "PCI" .... anyway, I came accross this by searching another way. This post is from this old thread.... best list I could find. Great work from Mel_24_! Obviously you'd just take from this list what was applicable to your house as it was specific to the OP's house, but it's a good list to give you ideas. I found it in this thread. viewtopic.php?f=31&t=26359&p=359767&hilit=scratch+windows#p359767 Mel_24_ Ok you guys asked for the list..here it is...i warned it was rather long! but you will see its repetative - i mainly just checkd things off as i went to make sure i checked everything i wanted. done room by room 1. Portico and under balcony • Why is ceiling under balcony different to portico? • Need to install x2 downlights the check switch once installed • Paint/maroka ok? • Check bricks for chips • Check mortar correct • Check cornice for cracks 2. Foyer/Hallway • Door stop for entry door • Check door opens/closes/locks • Door stop for garage door • Down lights line up – fixed yet? • Ceiling & Check cornice for cracks • Check door + paint • Check floor tiles inspect for scratches • Check skirting • 20mm maximum gap between door and FFL • Check light switches • test alarm • Electrical plan checked for consistency? 3. Formal living • Wall between stairs and formal living – check wall quality – needs painting, change skirting to 1 full piece instead of 2 pieces, make wall flush with other wall. Install timber capping on stepped part of wall, check new wall doesn’t conflict with light switch (refer to standards and tolerance – architraves and skirting are defective if not aligned and flush) • Ceiling & Check cornice for cracks • Paint • Power points work? • Light switches work and correctly linked • Doors open fine and don't smash the wall (door stopper?) • Window opens and closes correctly • Windows and frames not scratched inside and outside • Check carpet • Glass manufacture problem in door? • Check aircon location • Electrical plan checked for consistency? 4. Dining incl study nook • Move light switch • Handles on study nook door – make sure set straight and any holes filled check doors open smoothly • Check for any chipped tiles • Check for any paint imperfections • Check skirting for any damage • Check windows work and lock • Ceiling & Check cornice for cracks • Power points work? • Light switches work and linked correctly? • 20mm maximum gap between door and FFL • Light switch positioned correctly? • Check aircon location • Electrical plan checked for consistency? 5. Kitchen • Check area behind fridge is sealed • Remove comments left by contractors • Aircon duct locations • Ceiling & Check cornice for cracks • Paint • Power points • Power point for dishwasher • Light switches linked correctly? • Windows opens and closes correctly • Windows and frames not scratched inside and outside • Check floor tiles inspect for scratches • Check kitchen cabinet doors work properly ensure they line up, check for any marks, dents scratches etc. • Check laminate benchtops for uniform joints, aligned etc • Test tap • Plugs? • Inspect rangehood ok • Check filled wrong downlights are fixed and painted properly • Check filled phone point fix up area filled and painted properly • Electrical plan checked for consistency? • Stove missing • Check if tiling around splashback complete 6. Family • Aircon duct locations • Ceiling & Check cornice for cracks • Paint • Power points • Light switches • Check floor tiles inspect for scratches • Windows opens and closes correctly • Electrical work defective if does not comply with project documents (aircon) • Check aircon location • Check spillage area is fixed and grouting is not stained (near window) • Electrical plan checked for consistency? 7. Rumpus • bifold door opens and closes properly and locks? • door stop for bifold doors? • Aircon duct locations • Ceiling • Paint • Power points • Light switches • Check floor tiles inspect for scratches • 20mm maximum gap between door and FFL • Check cornice for cracks • Check switches for rear and side of house (switch next to BF door) • Electrical plan checked for consistency? 8. Powder room • door stops? • Silver waste outlet in line with tiles • Ceiling & Check cornice for cracks • Paint • Power points • Light switches work and linked correctly? • cracked tiles? • Window opens and closes correctly • Windows and frames not scratched inside and outside • Check no scratches on mirror and shower screen • 20mm maximum gap between door and FFL • Test tap • Plugs? • Test toilet • Electrical plan checked for consistency? • Laminate cupboard and bench top ok? 9. Laundry • door stop • blind in door works properly? • Paint on glass part of door both sides? • Check doors for scratches • Silver waste outlet in line with tiles • Ceiling & Check cornice for cracks • Paint • Power points work • Light switches • cracked tiles • Doors open fine and don't smash the wall (door stopper?) • 20mm maximum gap between door and FFL • Test tap • Plugs? • Test metal cabinet and inspect • Electrical plan checked for consistency? 10. Garage • Area above rear door • Rear door has scratches on • Skylight in – watertight? Finished nicely? Correct size? • Paint • Power points • Light switches • Ceiling • 20mm maximum gap between door and FFL • Check cornice for cracks • Electrical plan checked for consistency? • Check door opening mechanically with remote – make sure opens smoothly • Inspect garage panel door 11. Stairs incl hallway at top of stairs • Check lights work • Check 6th stair was repaired prior to carpet • Handrail on balustrade chipped • Stain capping on new wall next to stairs • Window and architrave at top of stairs dented • Paint Check cornice for cracks • Ceiling • Check floor tiles inspect for scratches • Window opens and closes correctly • Light switches & Power points • Check size of wall feature (2mx0.8?) • Check painted under balustrade capping at top of painted wall • Check carpet • Electrical plan checked for consistency? 12. Main bedroom incl intermediate area and balcony, and 2 robes, rain catchment area next to intermediate room • Ceiling Check cornice for cracks • Paint • Power points • Light switches • Windows wind up properly • Doors open fine and don't smash the wall (door stopper?) • Check carpet • 20mm maximum gap between door and FFL • Check aircon location • Electrical plan checked for consistency? • Check rain catchment area – not rusting • Check balcony – maroka had spilt paint on • Check balcony tiling • Check timber structure over balcony • Check rails on balustrade cleaned • Clean bricks on window sills 13. Ensuite • Silver waste outlet in line with tiles • Wall tile is not the tile selected – awaiting d’lorenzo’s response. Standards and tolerance advise substitute requires written agreement of owner. • Wall tiles below and above vanity do not line up – need to be fixed to comply with standards and tolerances document • Move towel rail form above toilet to below window – ensure does not conflict with door. Check where rail was to ensure fixed and painted OK • check all downlights that they do not have insulation in direct contact. Check lights in bathroom to ensure there is no beam in the way to stop light being centred. Also ensure they aren’t too close to any beams • Check cabinet doors work properly and finish and ensure they line up Laminate cupboard and bench top ok? • Check no scratches on mirror and shower screen • Paint & Check cornice for cracks • Ceiling • Check floor tiles inspect for scratches • Window opens and closes correctly • Light switches linked correctly • Test tap and shower taps • Plugs? • Test toilet • Power points • Electrical plan checked for consistency? • 14. Media room • Paint • Ceiling & Check cornice for cracks • Check floor • Light switch • Power points • Check window • Check frame • Check aircon location • Electrical plan checked for consistency? • Check carpet • Check skylight in roof through media room window – finished nicely? 15. Hallway incl linen press • Paint • Walls • 20mm maximum gap between door and FFL • Check cornice for cracks • Electrical plan checked for consistency? • Check carpet • Check linen press 16. Bedroom 2 incl robe • Check size of aircon vent blocking robe – only suppose 0.2m of robe see plan • Paint • Ceiling & Check cornice for cracks • Check floor • Light switch • Power points • Check window • Check frame • 20mm maximum gap between door and FFL • Check aircon location • Electrical plan checked for consistency? • Check carpet 17. Bedroom 3 incl robe • Paint • Ceiling & Check cornice for cracks • Check floor • Light switch • Power points • Check window • Check frame • 20mm maximum gap between door and FFL • Check aircon location • Electrical plan checked for consistency? • Check carpet 18. Bedroom 4 incl robe • Paint • Ceiling & Check cornice for cracks • Light switch • Power points • Check window • Check frame • 20mm maximum gap between door and FFL • Check aircon location • Electrical plan checked for consistency? • Check carpet 19. w/c • check tiling for chips/scratches • check floor waste outlet direction • check painting • check window works • 20mm maximum gap between door and FFL • Check cornice for cracks • Test toilet 20. main bathroom • bath tub tap missing? • check if switches correspond with lights • Silver waste outlet in line with tiles • Silver waste outlet scratched – require replacement • check for any chipped or cracked wall, floor, bath tiles etc • check grouting is complete in all areas • check painted areas for marks, chips, scratches • check painting of door – both sides • check mirror, taps, shower screens • Check cabinet doors and benches work properly and finish and ensure they line up • Check no scratches on mirror and shower screen • 20mm maximum gap between door and FFL • Test tap and shower taps and bath tap • Plugs? • Electrical plan checked for consistency? • check all downlights that they do not have insulation in direct contact. Check lights in bathroom to ensure there is no beam in the way to stop light being centred. Also ensure they aren’t too close to any beams • Paint • Ceiling & Check cornice for cracks • Check window • Check frame Front of house • roof tile out of place above intermediate room window. Irregularity needs to be fixed • paint around windows weathered stone • wonky glass in French door • paint between maroka and door • spots of paint and chips in maroka and bricks • driveway, entry path and pave under balcony missing • check ceiling under balcony – why is this ceiling different to portico? • 2 downlights under balcony missing • Sensor light location wrong – sense both people walking in path and cars driving up driveway • Clean balustrade on balcony • Clean bricks on window sill outside main bedroom • Paint missing maroka area ironstone • Paint rail on balcony ironstone • Check if bricks are cleaned properly • Check downpipes are secure and fixed • Check cornice for cracks under portico and balcony • Test tap • Electrical plan checked for consistency? • Missing pipe? See pics • Water meter broken? See pics East side of house incl RW • gutters require fixing – still sticking up • paint around windows weathered stone • pipe for aircon leads • aircon box missing • trim excess part of slab that is going into neighbouring property • paint RW tank pipes • touch up scratch on RW tank • crack in RW tank slab • broken slab under 1st row bricks next to RW tank • Check if bricks are cleaned properly • Check downpipes are secure and fixed • Test tap • Electrical plan checked for consistency? • Mortar above RW tank • Paint on glass blind door both sides • Garage door scratched? • Check bunker light works West side of house • gutters require fixing – still sticking up • paint around windows weathered stone • drainage pipe grate next to dining • missing pipe near family side window see pic • paint vent from rangehood • paint back of down pipe and pipe fixing to wall not painted • check wire and positioning of bunker light to be installed • pipe to electricity box too short – not covered properly • arrange for neighbours portaloo to be moved off my property • check water meter is not dented/broken • paint splashes on maroka • Check of bricks are cleaned properly • Check downpipes are secure and fixed • Inspect mortar • Electrical plan checked for consistency? Rear of house • roof tile out of place – north east corner • mountain mist on eave • paint around windows weathered stone • wonky glass on bifold door • broken pipe in rear yard – remove dirt and reinstate • fill missing mortar in NE corner of house • check if positioning of lights conflict with down pipes hold our light in position • check bifold door works • check bifold door now closes properly • door stops for bifold door? • Check metal sill above bifold door – bowing? • Check of bricks are cleaned properly • Check downpipes are secure and fixed • Electrical plan checked for consistency? Hope you all enjoyed that!!! I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: What to look for at PCI ? 3Apr 20, 2011 4:57 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. We hired Darbecca to do every stage inspection, and I strongly recommend them to anyone that asks me. They were amazing. Thorough reports with photos at every stage,… 6 7144 i would not be signing anything on the day read your contract about when builder submits final invoice generally, have to meet builder within 7 days of receiving final… 1 4747 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11589 |
