Browse Forums Building A New House Re: Windows Installed Before or After Rendered House? 2Jun 24, 2006 2:45 pm Yes, mandatory to install them first.
Sometimes they are left out for a short time but only if the job has to continue and they are'nt ready from the manufacturer but a complete pain in the neck to try and fit later. Plaster sheet, you may get away with it for a short time so long as the opening is protected from weather but solid plaster no way. The plasterer needs and uses the reveal (edge) of the window frame to trowel to. The spacing of the studs looks pretty large especially for a load bearing wall. 3 1638 yes indeed, thank you for all your replies I do appreciate. 15 3280 Youre not wrong. It was only because I read it on another forum that I asked my rep during tender stage about the wrap (NSW) and was told it wasnt required/automatic on… 10 5854 |
