Browse Forums Building A New House 1 Apr 17, 2011 9:17 pm What would you feel if you had double story houses on either side of your single storey home?
We have an option to put an offer in on a block of land in a private estate... there is a chance though that double storey houses "could" be built either side.... do we take the chance and not worry about it... what would you do? Hubby is a bit unsure and worried about the "sun" factor..... Re: Double storey houses each side of your single storey 2Apr 17, 2011 9:20 pm I was very thankful there were no double stories built beside, behind or opposite us. There was always a risk obviously when we bought the land, but we liked the block too much to consider not buying it. We just hoped they would all be single story Un;ess there's a convenant saying only singles, then you'll get the risk anywhere you purchase Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Double storey houses each side of your single storey 5Apr 18, 2011 10:01 am It really depends on how your block is orientated and how wide the blocks are. As far as access to sunlight goes, it doesn't matter if there is a double storey to your south side but to your north side it can be devastating if you have blocks 14metres wide or under. We have a double story to our north (the long side of our 14m frontage block) 1.5m from the fence line. We measured the shadow in the middle of June and found we only had 4 metres from the southern boundary with any access to sunlight. It has forced us to build a very long narrow house which we have had to go to a building designer for at considerable expense. So think carefully about orientation and whether the block has any other redeeming features which your are willing to forgo sunshine for! Re: Double storey houses each side of your single storey 6Apr 18, 2011 10:32 am If the houses were already built then i would not build there but if they were both vacant blocks then i would it would just be bad luck if they were built after you but i think that you will need to be notified through council (i guess it depends on which council). We had to think long and hard about our block (only single story can be built but so can be transportables) and in the end decided to go for it if one comes up after we have built there is nothing that i can do. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: Double storey houses each side of your single storey 9Apr 18, 2011 3:48 pm we are in an estate that nearly every house is a double store. There is only 1 single storey that we know of. There will be limited private space outside and they are now trying to sell and having trouble. Re: Double storey houses each side of your single storey 10Apr 18, 2011 3:59 pm Get in quickly and build before they do. Generally they have to work plans around houses already built. Well that's what we had to do with our double We had to dig up the cross over, get privacy windows etc to cater to the single on the other side. I think if we had built earlier would have had a few benefits on the design we wanted. Re: Double storey houses each side of your single storey 11Apr 18, 2011 4:45 pm The sales guy did mention that if they did build double storey beside us, they had to have windows on the side of the house up high, not full standard windows so we could have our privacy... You are right also right, if we get in first it would be better! Finger crossed..... just have to convince hubby now! Re: Double storey houses each side of your single storey 12Apr 18, 2011 7:06 pm I thought you would want your house to be surrounded by many double storey houses? This way your house is the least expensive among the more expensive houses, hence upping your house value... That's a different perspective -Site Start - 27th Jan 2011 Re: Double storey houses each side of your single storey 13Apr 18, 2011 10:22 pm Vtac82, would you really rate the theoretical increase in value for your house (dubious logic anyway since so many people prefer not to be overshadowed by double stories) above the comfort and well being of yourself liveing in the home?? Re: Double storey houses each side of your single storey 14Apr 18, 2011 10:28 pm vtac82 I thought you would want your house to be surrounded by many double storey houses? This way your house is the least expensive among the more expensive houses, hence upping your house value... That's a different perspective I'm just wondering why would you assume double storey homes are more expensive? There's plenty of single storey homes on his forum that are more valuable than some of the double storey homes on the forum. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Double storey houses each side of your single storey 15Apr 20, 2011 8:27 pm We are going to go and have a look at the block of land we like to see where the sun rises and sets.... titles don't come through to Oct/Nov, but not holding breath.... Re: Double storey houses each side of your single storey 16Apr 21, 2011 12:43 pm Bam single story Un;ess there's a convenant saying only singles, then you'll get the risk anywhere you purchase A relative is in an area where there is a single story covenant and her block is only 300sqm (widow not wanting the maintenance of a large block). Unfortunately the house next door had a second story extension put on it and got away with it by obscuring the windows. There was no consideration of loss of sunlight etc. to her living areas. Now that there are private companies doing building permits there seem to be less and less regulations that are abided by and councils don't want to get involved. If you are totally comfortable with the possibility of double stories next to you then go ahead, but if you have doubts make sure you do some more research. Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8102 Not unless you have managed to put it as a special condition into the contract somehow. 1 6150 1 4521 |
