Browse Forums Building A New House 1 Apr 15, 2011 6:02 pm Hi, We have decided to build again (6 months after moving into our new house) and have bought a block of land in Sandhurst. we are required to render the whole house and was wondering if anyone can give us an idea of what this may cost? We are looking to build a double story home of about 26 squares. We also have to have eaves, does anyone know the cost per meter of 600mm eaves? Ta Re: Cost of rendering whole house and of having eaves 2Apr 15, 2011 8:49 pm I got a quote for rendering $15000, but this has only just been the first one, we are only about 170sqm. Make your own Organic Vegetable Patch, Learn How to Build a Pergola http://www.homestyledesign.com.au Re: Cost of rendering whole house and of having eaves 3Apr 15, 2011 10:38 pm We have to have 600mm eaves, but the house we chose already had 450mm so the upgrade was only $1100 for approx 32 squares... (single story) So if you choose a house that already has them, it can help! I am guessing it would be the same with the render! Re: Cost of rendering whole house and of having eaves 4Apr 15, 2011 10:57 pm If the entire house has to be rendered, you could look at an alternative material such as Hebel. I think it may work out cheaper to use that and render than to have brink and render. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Cost of rendering whole house and of having eaves 5Apr 16, 2011 1:26 pm WOW you guys!! Can't believe the avenue is going to lose you so soon! No idea about your eaves, but we had both houses quoted for render to facade. The PD double story that we didn't build worked out at just under $10k & the single story Carlisle about $3k. Conclusion; either double is dearer, or PD. Or both? Will probably depend on your builder! Good luck Building Carlisle Homes "Monaco" @ The Avenue at Casey What's happening?... Handed over July 28, now making it home Follow our progress:: http://destination3977.blogspot.com/ The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4225 |
