Browse Forums Building A New House Re: retaining wall 2Apr 13, 2011 5:13 pm Dave0363 what would charge to do a sleeper retaining wall out treated pine about 18 metre long 3 sleepers high pretty cheap. I got 19 meter wall 1.5 meters high, steel & concrete slab construction for $8400. I would guestimate in the order of $500 - $1000 for labour + cost of supplies. If its easy access (ie can get wheel-barrow through for sleepers) then it will be the lower end of the scale. If heavy lifting is involved, then its a different story. Why are priates scary ? Because they yaargh.. Re: retaining wall 3Apr 13, 2011 6:02 pm Sorry to hijack you topic Dave. Can't help you as I know nothing about it, but also have a rough quote for mine. 3 walls, approx 4.5 m long x 500mm high, 7 m long by 600mm high and 6m long by 500mm high. These would be done in Tasman blocks with concrete footing and drainage behind. Approx price $3300. What do you think? taki Building Havana Elite with side HT with MJD 20/04/11 DA approved by council 06/06/11 cut/fill 08/06/11 piering 20/6/11 slab 11/8/11 frame complete 18/9/11 lock up 28/11/11 handover booked Re: retaining wall 4Apr 13, 2011 6:29 pm Hi Taki... I just had 2 walls done in Tasman blocks, with footings and drainage connected to stormwater as follows - Wall #1 - 24m long, 3 courses high, plus capping $5,990 Wall #2 - 18m long, 4 courses high, plus capping $5,980 Hope this helps! PS they look fantastic!!!!! Helena Re: retaining wall 5Apr 13, 2011 6:33 pm Hi Helena, The price sounds about right then, however there was no mention of connecting to storm water but will see about that. Were yours concrete filled, because that was the suggestion. I think I would prefer the bluestone or pebbly type fill. Thanks Building Havana Elite with side HT with MJD 20/04/11 DA approved by council 06/06/11 cut/fill 08/06/11 piering 20/6/11 slab 11/8/11 frame complete 18/9/11 lock up 28/11/11 handover booked Re: retaining wall 6Apr 13, 2011 6:48 pm Ours were filled with that pebbly stuff thats like blue metal but multi coloured (if that makes sense) they were also backfilled with the same to allow for drainage. On the quote its called "Drainage Agg"... Re: retaining wall 8Sep 17, 2015 10:18 pm I am thinking of using concrete sleepers for a retaining wall but I am concerned about lifting the 80kgs two metres off the ground and lowering them into place. Love to hear about a safe way to do this. The wall is a part of a boundary fence so access is not great. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5603 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16312 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7025 |
