Browse Forums Building A New House 1 Apr 08, 2011 12:54 pm Hoping to get some opinions on solar design for the new house. Here's what I have come up with so far: 1. We have garage with skillion roof facing due north. Garage is 6x6 so roof area is a little bigger with 10 degree angle and 600mm eaves on 3 sides. This will be reserved for solar panels. BTW, the meter box is on the garage wall too so this seems ideal. 2. We have a roof facing north west. Our plans include a solar hot water heater and the builders have placed the collectors right in the middle of that roof. We are also thinking about putting in solar heating for a pool on that roof section which would probably fill the rest of the space. Originally I thought about moving the hot water panels to one side but if I understand correctly, pool heater tube installation is pretty flexible so perhaps it would be better aesthetically to leave the hot water panels in the middle and then surround them with the pool tubes? Re: Solar design 2Apr 08, 2011 2:32 pm Have you decided what goes on the roof? Its normally cheaper to put solar panels on a steel roof rather than tiles, and there is less chance of damaging the roof during installation and maintenance. Any chance of making the roof a bit steeper as 15-20 will improve efficiency. Here is a link on panel orientation. http://www.anewhouse.com.au/?p=391. Sorry don't know much about pool systems The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6456 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13761 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19467 |
