Browse Forums Building A New House 1 Apr 06, 2011 9:58 pm Hi I'm new to the forum, and building. My wife is keen to have polished concrete in our entrance, kitchen, lounge, family and dinning room. The builder is installing a 'M' class waffle slab. I have 2 questions 1) Is it possible to polish a 'M' class waffle slab? 2) Can this be done after handover? I look forward to hearing from other members Thanks in advance Re: Polished Concrete 2Apr 06, 2011 10:04 pm There are a LOT of polished concrete threads... It might be worth doing a search for them, quite a bit of info you might find of interest. However, a start would be : Grind the concrete 3 days after the slab is poured. Cover it then finish the polishing process before second fix. Where you are coming from is where you are going to... Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11005 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3154 |
