Browse Forums Building A New House 1 Apr 03, 2011 9:22 pm Hi all Just following on from another similar topic, hoping others can share their experiences. I am soon to be heading to pre-start and I'd like to ask them to remove the light fixtures and replace them with just a powerpoint/junction box in the ceiling to have downlights installed independently after I move in. Has anyone else done this and is it fairly standard? Or have your builders told you that they cannot build the house without lighting? Thanks in advance Re: Electrical/Lighting - build without lighting? 4Apr 05, 2011 10:50 am jasmin3 Hi all Just following on from another similar topic, hoping others can share their experiences. I am soon to be heading to pre-start and I'd like to ask them to remove the light fixtures and replace them with just a powerpoint/junction box in the ceiling to have downlights installed independently after I move in. Has anyone else done this and is it fairly standard? Or have your builders told you that they cannot build the house without lighting? Thanks in advance Our SS, told us we were lucky to get away with it now in WA, as he mentioned that now there has to be lighting in every room. Got the downlights installed yesterday and they look good!!! ---- Building in Banksia Grove We have keys - 31st March 2011 Re: Electrical/Lighting - build without lighting? 5Apr 11, 2011 7:59 pm just in case anyone else had read this and was wondering, I asked my mortgage broker about the lighting situation, and have been advised that bankwest (my lender) won't approve the loan/house with no lighting. This is partly to do with the lenders mortgage insurance. So not sure if this is the same for other people, but looks like I will have to get the standard lighting installed. Re: Electrical/Lighting - build without lighting? 6Apr 12, 2011 10:08 am hmmmm, either the valuer didn't look to hard at our place or the fact that we had given them invoices for the lights & installation of them!! We went with bankwest as well!!! ---- Building in Banksia Grove We have keys - 31st March 2011 Re: Electrical/Lighting - build without lighting? 7Jun 13, 2011 10:18 pm Would it work if you had (say) one light in the corner of your room and Clipsal 413 in three other positions ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ● = Clipsal 413 ● = Downlight wired in with the three other 413 points P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Electrical/Lighting - build without lighting? 8Jun 13, 2011 11:24 pm you only need one clipsal 413 per switch. e.g. for a bedroom where by a light turns on 4 downlights, only one clipsal 413 is required. If you builder does not allow you to install clipsal 413 instead of downlight, what you can do is install one light in the position of the downlight and after handover just daisy chain it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Electrical/Lighting - build without lighting? 9Jun 13, 2011 11:46 pm Are you looking at not getting your builder to do any lighting at all? We are getting junction boxes in the areas we want downlights (ie main living, bed 1, etc) but are having regular lighting installed in other areas (like minor bedrooms) We are going through Bankwest too, our mortgage broker is aware of what we are doing with lights and hasn't mentioned anything re this to us? Re: Electrical/Lighting - build without lighting? 10Jun 14, 2011 12:40 am wrexter Pepsi_Drinker Would it work if you had (say) one light in the corner of your room and Clipsal 413 in three other positions ? P_D you only need one clipsal 413 per switch. e.g. for a bedroom where by a light turns on 4 downlights, only one clipsal 413 is required. If you builder does not allow you to install clipsal 413 instead of downlight, what you can do is install one light in the position of the downlight and after handover just daisy chain it. Ahhh........I like your thinking !!! Assume a "Degree of difficulty" of (say) FIVE for your 1st fix Sparky to install the (additional) 413's, once the insulation is in, ceiling is installed, carpets, bed and everything else is in place, the "Degree of difficulty" of installing the other 413's would be significantly higher, say TEN. Given the well-publicised *cough* "additional markup" by builders, would it still be cheaper to get an after-handover Sparky, or would you be better just sucking it up and paying the builder for the 413's ?? (All things being equal....) Thanks, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28964 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28441 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 20990 |
