Browse Forums Building A New House Re: How long does rendering take? 2Apr 01, 2011 7:55 pm Only our facade was rendered... took a few hours on each coat Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 |
