Browse Forums Building A New House 1 Mar 31, 2011 10:32 am Hi Just wondering if anyone has or is building in Waterview Ridge estate in mount martha? I am just wondering how much more we would be looking to build a house on one of the blocks there given most are on slopes. Did you use a volume builder or a independent builder? Any advice or experience with sloping blocks would be wonderful thanks Re: Anyone built/building in waterview ridge estate mount ma 2Nov 03, 2011 7:15 pm We're building in Waterview Ridge. Site costs came in at around $18000 with a volume builder. Not too bad as we had around a two metro fall across the build site (1000mm cut at the rear, 800mm fill at the front). Re: Anyone built/building in waterview ridge estate mount ma 3Nov 18, 2011 5:21 pm Is anyone else on here building in Waterview Ridge? I'd be interested in hearing about your build, in particular about how the new bushfire regulations have affected your plans. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8310 Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13588 I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks… 1 14362 |
