Browse Forums Building A New House 1 Mar 26, 2011 11:20 pm I have recently been informed by my builder that the frame stage of my house has finished and they asked me to pay. I went to the site today and found that a few pieces of short lumber (horizontal) used to joint vertical lumber are actually defective and there are huge holes in them. Also I found a few smaller holes in the roof truss lumber. Given this has been inspected by building surveyor should I raise them to my builder? Will these lumber cause an issue? Should I pay them before these issues are solved? I have taken photographs and attached them here. https://picasaweb.google.com/sionghua/D ... 4Ht8KWIUg# Re: Defective lumber in house frame 2Mar 27, 2011 6:39 am Don't stress, Timber is graded to code. Defects are acceptable to certain levels and don't affect it's strength. If it was exposed it would be more an aesthetic problem Landscape Design & Construction http://cherub.squarespace.com/ This is 100% true. You can not hang anything on steel frames. very frustrating 8 8063 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8505 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 |
