Browse Forums Building A New House 1 Mar 22, 2011 5:35 pm Hi everyone, We are in the process of looking to build two town houses on our property. What builders would you recommend/build two houses on the one land. So far Metricon seems to be the only ones with a seperate Multi-Dwelling section. I called Porter Davis and they said you have to subdivide the land first. So my questions are: 1) Names of building companies who make two homes on the one property 2) Is sub-dividing your land a difficult expensive process? 3) Is going with a private builder a better idea or with a larger company? Thank you for you help- much appreciated. Re: Multi dwelling homes on one property 2Mar 22, 2011 9:06 pm it can be expensive. Have you done town planning yet?? Portadavis dont know what there are saying. You can not usually subdivide until you have done townplanning and you can not do townplanning with out basic drawings. Most people subdivide (seperate titles) once houses are finished, paper work cost 5K plus. Also there are fees to bring in electricity etc which can be around 6K. PLease note this is based for victoria. Re: Multi dwelling homes on one property 3Mar 23, 2011 1:24 pm Have not done town planning yet- sort of looking at all information avenues. I am in Victoria. Maybe I could look at Metricon to do a feasability study (which apparently is free). They seem to be the only dedicated ones with floor plans etc. on their website specifically for Multi-dwelling units. Will also look into National Builders Group. Any other recommendations. Surely building two houses on the land would be common? Seen them around quite a bit over the last few years. Re: Multi dwelling homes on one property 4Mar 27, 2011 11:56 am Do not go to builders to do town planning, it is not the best way. I've been involved with iver 1000 town planning projects and seen far too many people chosing builders first to select a design and sign up with them to build two homes on one site just to see them loose everything in the courts because they did not know the procedure and regulations to do the town planning. The design must comply with all town planning regulations and you must prove to council why your land should be given permit to build two homes in it. In Victoria must do Rescode 55 as minimum. If yor block of land is bigger than 1000sqm easier to subdivide but if less than 1000sqm you will need full town planning. Only use expert design consultant to ensure design complies with as many regulations as possible and be able to convict council the reasons for the two unit development. You will need various town planning drawings including planning reports, full feature neighborhood surveys and full planning drawings. Re: Multi dwelling homes on one property 5Mar 27, 2011 12:37 pm I would talk with council planning first,find out what zoning[high or low density] ask if land needs to be subdivided etc Re: Multi dwelling homes on one property 6Mar 27, 2011 8:43 pm Here are some builders I know doing multi-dewellings, but it's not recommanded: Metricon, National builder group, clarenden, Hometec I have talked with their sales representatives and I think they have no ideal about any of these. So don't risk. You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1690 The setback from the kerb is 4m. It is council land to provide an area for services like sewer main, gas mains, water mains, underground power or poles for overhead power,… 4 2395 |
