Browse Forums Building A New House 1 Mar 14, 2011 12:30 pm I was just wondering what your thoughts were on installing ducted aircons cost wise? Should I: A) just install ducting and leave connecting unit until later B) install the whole lot and be done with it C) Leave it until later and have someone else come in and fit the ducting and unit after handover Which which be the most inexpensive and efficient method? Re: What's your opinion on aircon before or after the build? 2Mar 14, 2011 1:53 pm My opinion would be that it would be more cost effective and efficient to install during the build process. Anything such as ducting, wiring etc that can be done prior to finalising the house will be cheaper then getting someone out after the fact, and of course a lot less stressful/messy when everything is finished. But then again it goes on can you afford to have the whole unit installed now? If not then getting the ducting now and putting in unit may be more beneficial to you. However if it was me (and I'm looking right now to build) I will be getting air conditioning done now and get it over with, its all there and I can rest in peace without having to have people come out later to fix/add things later. Re: What's your opinion on aircon before or after the build? 3Mar 14, 2011 2:12 pm Our Builder had a promo for evaporative installed for $3k... We upgraded to Reverse cycle for $8k. With flooring, window treatments, landscaping... there is enough cash payments to be made!! I think it will be worth every penny. Also, you have to then organise it to be installed, I know it sounds petty, but waiting around for tradesmen is frustrating! lol. Building with Life$tyle Homes in Perth SOR Key Dates on First Page of my Thread viewtopic.php?f=31&t=38761 Re: What's your opinion on aircon before or after the build? 4Mar 14, 2011 2:32 pm We're doing ours after the build. Simply because the included aircon @$4k~ was a a pretty crappy unit..I could get a much better unit privately for the same / less cost.. Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6140 these look like missing batts. Go up and take a look. But yeah moisure meter is a completely different tool 4 9458 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15792 |
