Browse Forums Building A New House 1 Mar 12, 2011 9:22 pm Hi Everyone, First of all I would like to say how wonderful this website is, it had help me to learn a lot of infomation about what it takes to build a dream home, although I am yet to have a practical experience. Anyway, I am now still at stage one where I need to pick a home builder for my dream home. It comes down to below 4 builder and I am hoping to get some vote from you guys. 1. Metricon 2. Clarendon 3. Plantation homes 4. Dixon I am hoping to build a 27-30 squares single story house where my budget is around 200K. PLease help me Re: Need your suggestion to select a QLD builders 2Mar 13, 2011 10:35 am davidding1000 I am hoping to build a 27-30 squares single story house where my budget is around 200K. PLease help me First of all, if you are thinking of building anything of that size with the first 3 builders for the $200k budget you say you have forget about having much in it. The last of the four could possibly accomodate but you won't get much bang for your buck. The rough rule is this - forget about base prices as they are never a true indication of the end contract price. For a house of around 250m2 with all site works taken into consideration on a flat block you could in today's market with those first 3 builders pay in the vicinity of around $200k. However, that is without carpet, tiles, water tank, aircon, driveway, turf etc. Adding all these things to the build will probably push your bill up to around $240 - $250k. Like I said earlier, you may be able to do something of that magnitude with builder 4 but if you do a bit of research on product review you may find yourself questioning the possibility of any of the four. Hopefully that helps. Re: Need your suggestion to select a QLD builders 3Mar 13, 2011 12:11 pm Does the first one start with an M? If so, we are about to build with them so here is a good idea of what you can expect. We are building their cheaper range and upgrading a few things like ceiling height, door handles, ceasarstone bench and a few other small things and also added an outdoor room worth $8k. Our home is 21sq and came to $185k not including driveway/landscaping/upgraded electricals. Our land was flat already but soil was type M so added a bit to the cost. You could get what you want for your budget, but it will be a bare bottom home with all the cheapest options available. And I guess that's assuming your site costs aren't too high. Re: Need your suggestion to select a QLD builders 4Mar 13, 2011 6:42 pm As Mr Forgetful has said, it will be difficult to get a 27 - 30 square home for that sort of money. Our home is not by any means high end, but I believe will be good value for what we are getting and will be in the $250,000 plus region by the time we have landscaping, driveway, patio and fencing done etc. What I can say is we have been very happy with our builder to date, and I cannot see that changing over the last stages to completion. Check out our thread for details and others building with the same builder (search is you friend) Cheers, John and Marilyn Our build: viewtopic.php?f=31&t=39708&start=0 Retaining wall for fill side 3/12/10 Cut and fill 6/12/10 Screw Piers 17/12/10 Rear retaining wall 22/12/10 Under slab plumbing and electrics 20/1/11 Formwork and slab 29/1/11 Frames 01/02 Roof tiling 14/02 Doors,plumb, elect rough in 16 -21/02 Bricks 23/02 Plastering start 2/03 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11589 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8820 Thank for yes basically what to remove and what to add, where to place them 2 7332 |
