Browse Forums Building A New House Re: Hebel Blocks 2Mar 07, 2011 5:53 pm we built a Hebel-exterior house in 04. we've long since moved away, but when we've been past there in recent years, it doesnt look like the Hebel has aged all that well. you can see the individual panels at some angles under certain light, and hairline cracks have appeared in the render in some of the joins. Re: Hebel Blocks 3Mar 07, 2011 9:46 pm b0son we built a Hebel-exterior house in 04. we've long since moved away, but when we've been past there in recent years, it doesnt look like the Hebel has aged all that well. you can see the individual panels at some angles under certain light, and hairline cracks have appeared in the render in some of the joins. Was that with the blocks or panels? I have seen a local house built with the wall panels and it looks cheap and nasty but the blocks are used a lot in the uk and seem to weather well.and at 250mm wide it seems a solid alternative,coming in cheaper than brick veneer but will I pay the price down the track in expensive upkeep? & 7 years is not a good sign for wear and tear Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13857 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5938 1 6695 |
