Browse Forums Building A New House Re: Building a Waldorf or Marriot by Porter Davis 8141Sep 24, 2015 10:26 pm Hi karanasios and Chris & Heli, Thanks for replying to my questions! We just have our case lodged into regional office by SC and we really need to seriously think of windows size and location. @Chris & Heli, I just briefly check your downstairs windows and they look great and much better than the default one. The default sliding door on Alfreso side which is promoted to be 24*30 stacker doors doesn't position properly. I also like your idea to extend the office window width. We thought of having double glazing glass, but were told the low-e class glass in PD's promotion is also good so we probably won't upgrade them also due to cost concern. Re: Building a Waldorf or Marriot by Porter Davis 8142Sep 25, 2015 8:07 am We changed window size in the Home Theatre by making it much smaller, approx only 5% of floor area which was the smallest we could have under the building code. Wish we had no window in the home theatre though, now it's just more work to brick it up ourselves. Re: Building a Waldorf or Marriot by Porter Davis 8143Sep 25, 2015 10:09 am BbsWaldorf Hi karanasios and Chris & Heli, Thanks for replying to my questions! We just have our case lodged into regional office by SC and we really need to seriously think of windows size and location. @Chris & Heli, I just briefly check your downstairs windows and they look great and much better than the default one. The default sliding door on Alfreso side which is promoted to be 24*30 stacker doors doesn't position properly. I also like your idea to extend the office window width. We didn't change anything on the front. The facade is not able to be changed. So, once you choose it, well, with the Hampton facade at least, you get what you get. The only change we could make was upgrading to double glazed. BbsWaldorf We thought of having double glazing glass, but were told the low-e class glass in PD's promotion is also good so we probably won't upgrade them also due to cost concern. From memory the low-e glass was about 70% heat etc of double glazing. But it's been a while. Re: Building a Waldorf or Marriot by Porter Davis 8144Sep 25, 2015 10:28 am Jackula We changed window size in the Home Theatre by making it much smaller, approx only 5% of floor area which was the smallest we could have under the building code. Wish we had no window in the home theatre though, now it's just more work to brick it up ourselves. Yey! We tried the same, for the same reason. "Can we get rid of them entirely?" "No, you will not meet the energy rating if you do". Evidently in melbourne, they are more concerned about letting light and heat in, than preventing it escape through windows. Which makes sense given the number of hot days we have (it's not that many). Re: Building a Waldorf or Marriot by Porter Davis 8145Sep 25, 2015 10:57 am ChrisHeli Jackula We changed window size in the Home Theatre by making it much smaller, approx only 5% of floor area which was the smallest we could have under the building code. Wish we had no window in the home theatre though, now it's just more work to brick it up ourselves. Yey! We tried the same, for the same reason. "Can we get rid of them entirely?" "No, you will not meet the energy rating if you do". Evidently in melbourne, they are more concerned about letting light and heat in, than preventing it escape through windows. Which makes sense given the number of hot days we have (it's not that many). Yeah I saw them in your blog. It's strange though, it's increasing window size that usually decreases energy rating, not the other way around. Our window ended up being a single 1.2sqm stretch, I think your choice is better if the sitting position is on the window side. At the moment, we are using a massive TV to block out window Re: Building a Waldorf or Marriot by Porter Davis 8146Sep 25, 2015 11:47 am I like that! We went for the smaller windows, so that we could easily block them out. At one point we were thing of putting the TV in between the windows, but that is the short axis of the room (only 3.5m) so given the doors are a large 920mm wide (each) we'd have our noses on the TV. We we've rotated it by 90 degrees, and are going to put the TV at the end (on the left as you walk into it) and make use of the natural framing created by the plumbing stack. Now, finding a decent set of couches or chairs for four people to fit in 3.5m is quite a challenge! Re: Building a Waldorf or Marriot by Porter Davis 8147Sep 25, 2015 12:58 pm We just had the flooring guy walk through the house and check things. The slab has been finished within normal building tolerances, so nothing for PD to fix. However, the slab's variation is not within the flooring manufacturers tolerances; they are tighter than the building code. So now looking at having the floor levelled. I'm still awaiting a call back from the leveller, so I have no idea of costs involved. Has anyone else who has done flooring post handover run into similar issues? If so, where they you decide to do about it? . Re: Building a Waldorf or Marriot by Porter Davis 8148Sep 25, 2015 4:36 pm ChrisHeli I like that! We went for the smaller windows, so that we could easily block them out. At one point we were thing of putting the TV in between the windows, but that is the short axis of the room (only 3.5m) so given the doors are a large 920mm wide (each) we'd have our noses on the TV. We we've rotated it by 90 degrees, and are going to put the TV at the end (on the left as you walk into it) and make use of the natural framing created by the plumbing stack. Now, finding a decent set of couches or chairs for four people to fit in 3.5m is quite a challenge! That's exactly what I would've done also in your situation with the two side windows, the worst thing would be to have glass diffusion behind your main speakers, but it won't really impact your surround channels. Get a comfortable 3 seater, they're usually large enough for fit 4 people. We got a black one with a chase opposite the door, we can quite comfortably sit 4 people. Re: Building a Waldorf or Marriot by Porter Davis 8149Sep 25, 2015 4:43 pm Hi all, updated blog post for those of you interested - Happy Friday http://waldorf43.blogspot.com.au/ Re: Building a Waldorf or Marriot by Porter Davis 8150Sep 25, 2015 9:33 pm Lisjac Hi all, updated blog post for those of you interested - Happy Friday http://waldorf43.blogspot.com.au/ Is the Spotted Gum flooring the laminate, or real hardwood? We're having trouble getting a sensible answer about real hardwood floor Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building a Waldorf or Marriot by Porter Davis 8151Sep 27, 2015 11:19 am For those of you who have taken possession: With whom did you insure? AAMI could not insure over the web as the calculated value was $1.1-1.3m and they would not offer insurance. 7 years ago I used to work for AAMI, but I've forgotten if they just value the home (as in construction costs only) or combine it with the costs of the land, which tends to float the value of the land. Or if I need too. GIO failed for the same reason (but I think they are both owned by Suncorp, so use a common back end). Real insurance etc managed to ask the right questions, namely, how much would it cost to build the house today, new. Can answer that one! But the budget ones don't appeal (perhaps it's a hangover from my AAMI days?). So, whom have people insured their homes with? Re: Building a Waldorf or Marriot by Porter Davis 8152Sep 27, 2015 11:50 am We insure with Westpac, because it's easy (we have our mortgages with them)... Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building a Waldorf or Marriot by Porter Davis 8153Sep 27, 2015 4:09 pm We are with CGU and pretty happy with their service. Re: Building a Waldorf or Marriot by Porter Davis 8154Sep 28, 2015 10:15 am We ended up going with CBA in the end. Heli was happy with it. AAMI was around $2K, CBA was just over half of that. Re: Building a Waldorf or Marriot by Porter Davis 8155Sep 28, 2015 10:36 am AAMI has gone crazy over the last few years with their very unrealistic premiums. Do you know who is underwriting CBA home insurance? Re: Building a Waldorf or Marriot by Porter Davis 8156Sep 28, 2015 3:57 pm mirz AAMI has gone crazy over the last few years with their very unrealistic premiums. I blame GuideWire and their modelling package that they use. mirz Do you know who is underwriting CBA home insurance? Not sure, I'll have to look at their PDS. Re: Building a Waldorf or Marriot by Porter Davis 8157Sep 28, 2015 9:25 pm I'm thinking of install cavity doors for all WIRs and ensuites of all 3 non-master bedrooms, but SC told me it's not suitable for WIRs as they're too narrow. Have you installed cavity or any other doors onto your WIR & ensuites. have you customized your Terrace baluster? The quotation only says it's 1100m high and I guess the display home one must not be the default, so not sure what default will look like. Re: Building a Waldorf or Marriot by Porter Davis 8158Sep 29, 2015 12:30 pm ChrisHeli mirz AAMI has gone crazy over the last few years with their very unrealistic premiums. I blame GuideWire and their modelling package that they use. mirz Do you know who is underwriting CBA home insurance? Not sure, I'll have to look at their PDS. From the PDS: Things to know before you Can: This SPDS is issued by Commonwealth Insurance Limited ABN 96 067 524 216 AFSL 235030 (CIL). CommInsure is a registered business name of CIL. CIL is a wholly owned nonguaranteed subsidiary of the Commonwealth Bank of Australia ABN 48 123 123 124 (Commonwealth Bank) and is the insurer for the CommInsure Home Insurance policy. The Commonwealth Bank and its related entities are jointly referred to as the Commonwealth Bank Group. In the ACT, TAS and WA, CIL offers Domestic Workers’ Compensation Cover as an agent for Allianz Australia Insurance Limited ABN 15 000 122 850 (Allianz). The Commonwealth Bank Group (other than CIL) does not guarantee the obligations or performance of CIL or Allianz or the products they offer. CIL does not guarantee the obligations or performance of Allianz or the products it offers. Re: Building a Waldorf or Marriot by Porter Davis 8159Sep 30, 2015 1:09 pm looking for anyone who has the dec13 outdoor kitchen promotion Re: Building a Waldorf or Marriot by Porter Davis 8160Sep 30, 2015 7:49 pm deefeez46waldorf looking for anyone who has the dec13 outdoor kitchen promotion I think the Marbella at Williams Landing has it Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 13660 Not unless you have managed to put it as a special condition into the contract somehow. 1 6425 I do enjoy the drama:-D In his latest two videos he has started bringing security guards to site, I am waiting for the punch on to begin lol 6 46078 |
