Browse Forums Building A New House Re: Damp Proof Course 4Mar 01, 2011 4:41 am It should be the full width of the bricks. Any less and it creates a moisture bridge which defeats the purpose. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Damp Proof Course 5Mar 01, 2011 7:18 pm bashworth It should be the full width of the bricks. Any less and it creates a moisture bridge which defeats the purpose. Thans Bashworth. I had a walk through in my suberb and found that in lots of the house it doesn't cover the entire width of the brick. In my house its about 20-25mm inside the outer face of brick. Is there an easy fix to this or need to pull down the entire brickwork? Re: Damp Proof Course 6Mar 01, 2011 8:12 pm In the UK there are a wide range of methods for providing an effective DPC such as injecting a sealant into the bricks but I am not sure what is available in Australia. Sorry but unless someone knows something I don't starting again and doing it properly looks like the solution The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Damp Proof Course 7Mar 13, 2011 8:05 pm bashworth It should be the full width of the bricks. Any less and it creates a moisture bridge which defeats the purpose. Builder is providing assurance letter from Engineer, Surveyor and an undertaking by the builder that this will not have any long term effect on the building. Is that enough? Re: Damp Proof Course 8Mar 13, 2011 9:08 pm I would be asking them to clearly explain in their letters how they know more than the people who wrote the Building Code and the Australian Standards and provide specific guaraantees for the life of the building, see below The Building Code of Australia and Australian Standard AS3700 Masonry Code require dpcs to be placed through the full thickness of the base of walls below floor level to form an impervious layer that keeps rising dampness out of the interior of the house to prevent lifting of tiles, and deterioration of walling, furnishings and floor finishes. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Damp Proof Course 9Mar 14, 2011 7:10 pm bashworth I would be asking them to clearly explain in their letters how they know more than the people who wrote the Building Code and the Australian Standards and provide specific guaraantees for the life of the building, see below The Building Code of Australia and Australian Standard AS3700 Masonry Code require dpcs to be placed through the full thickness of the base of walls below floor level to form an impervious layer that keeps rising dampness out of the interior of the house to prevent lifting of tiles, and deterioration of walling, furnishings and floor finishes. Thanks Bashworth. What else they can do without pulling down the whole house. I'm already in the 12th Month of construction. Tired of paying loan and rent. Is there any easy fix? Re: Damp Proof Course 10Mar 14, 2011 7:29 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Damp Proof Course 11Mar 14, 2011 8:13 pm bashworth Thanks again for providing valuable info. The building surveyor issued occupancy certificate. If DPC not installed properly how he issued the certificate? Isn't building surveyors role to see the compliance with the standard? Re: Damp Proof Course 12Mar 14, 2011 10:25 pm My SS said that we don't have a DPC and said that they don't need it as they spray a water proofing layer on the edges of the slab. Should I present them with the above AS and ask them to confirm in writing? Jason Building a modified Platinum MKII with Blueprint Homes. House Plan Contracts Signed: 18/10/2010 Prestart 21/10/2010 Sandpad: 14/1/2011 Slabbed: 27/1/2011 Brickwork: 15/2/2011 Roof: 18/3/2011 Re: Damp Proof Course 13Mar 17, 2011 3:54 pm I have not heard of a spray on DPC. Also the slab normally finishes up underground and the DPC needs to be above ground. I would definitely be asking your builder to show you the place in the regulations which approves his method! Regards The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Damp Proof Course 14May 10, 2011 4:36 pm khpatoary bashworth It should be the full width of the bricks. Any less and it creates a moisture bridge which defeats the purpose. Builder is providing assurance letter from Engineer, Surveyor and an undertaking by the builder that this will not have any long term effect on the building. Is that enough? Hi khpatoary Just wondering how you got on with your non compliant DPC. We have the same problem with our new home ..... the builder will not accept responsibility despite us advising that it is not in line with BCA or AS3700. It is their belief that the shortfall is current common building practice. Have you received your guarantee letters yet ..... how did you go about this? Please PM me if you wish? Looking forward to your update. SherWin Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20580 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6342 Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 7472 |
