Browse Forums Building A New House 1 Feb 15, 2011 9:15 pm Hi everyone We are currently going through pre-start and everything has been going great except for one item. The builder refuses to install a gas bayonet in the alfresco area due to this being 'under the main roof' due to 'inadequate ventilation if the area is enclosed at a later date'. But not to worry, "this can be easily installed through the cavitry after handover by a licensed plumber". After speaking to a number of plumbers it doesn't seem to be quite so easy and that we are likely to end up with some unsightly gas pipes. Going back to the builder to clarify but they are not being very helpful on this item. Has anyone encountered this problem before and have any advice/solutions?? Re: Builder refuses to install alfresco gas point 2Feb 15, 2011 9:21 pm omg, that sounds a bit rich! which builder??? we had it done by the builder, no probs with our builder. I've heard of some builders charging a lot more than is justified (because they can!) but not saying they won't do it. A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ Re: Builder refuses to install alfresco gas point 3Feb 15, 2011 9:31 pm i thought it was a pretty standard item these days. Ours was included by the builder as oart of the outdoor fireplace privision but we are putting in a wood fire so just had them relocate it to where the bbq will sit, no charge. unless you have built in doors then there is no reason that 'ventilation' would be a problem. Building at Sierra Estate. Re: Builder refuses to install alfresco gas point 4Feb 15, 2011 9:34 pm We have an alfresco that is enclosed by the house on three sides, and our builder installed a gas point no problems but I'm in Vic. As you said "pre-start" I'm guessing you are in WA.... I'm wondering if there may be some specific regulation regarding this for your state. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Builder refuses to install alfresco gas point 5Feb 15, 2011 10:42 pm idea1974 The builder refuses to install a gas bayonet in the alfresco area due to this being 'under the main roof' due to 'inadequate ventilation if the area is enclosed at a later date'. and yet its perfectly normal to have an *internal* bayonet for a heater.... Re: Builder refuses to install alfresco gas point 6Feb 15, 2011 11:49 pm joles We have an alfresco that is enclosed by the house on three sides, and our builder installed a gas point no problems but I'm in Vic. As you said "pre-start" I'm guessing you are in WA.... I'm wondering if there may be some specific regulation regarding this for your state. We've just built our home in WA, no regulation here re no outdoor gas point. We moved the one included in contract from the family room to where our alfresco kitchen will be outdoors. Alfresco has 2 enclosed sides. Sounds as though the OP's builder is being difficult/lazy Stand your ground as it definitely can be done......hmmm wonder which builder this is???? Cooper's Build - Perth NOR viewtopic.php?f=31&t=30525 Prelim- mid Sept 2009, Pre Start 2 Feb, Siteworks- 21 April 2010, Slab- 10 May, Deliveries- all by 26 May Bricking- 28 May - 26 June, Roof complete 5 Aug, Float 28 Aug, Lock up 16 Sept Cabinets 1 Oct, Tiling 22 Oct, PCI 18 Nov, KEYS 3 Dec 2010 MOVED IN 17 DEC 2010 Re: Builder refuses to install alfresco gas point 7Feb 16, 2011 6:43 am We are in QLD and couldn't have the gas point under the patio when we renovated our last house. We had to run the gas piped along the timber beams to the outer edge. Re: Builder refuses to install alfresco gas point 8Feb 16, 2011 7:58 am b0son idea1974 The builder refuses to install a gas bayonet in the alfresco area due to this being 'under the main roof' due to 'inadequate ventilation if the area is enclosed at a later date'. and yet its perfectly normal to have an *internal* bayonet for a heater.... Good argument I'd use this one & see whether the builder can reply to it ! Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Builder refuses to install alfresco gas point 9Feb 16, 2011 9:17 am Tamara1975 We are in QLD and couldn't have the gas point under the patio when we renovated our last house. We had to run the gas piped along the timber beams to the outer edge. Strange we put one in on our deck when we build last year, in Qld. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Builder refuses to install alfresco gas point 10Feb 17, 2011 2:25 am Thanks everyone for your advice. Luckily, some sanity prevailed and the builder has now agreed to put in a gas pipe, capped. We'll get a plumber out later to fit the bayonet. Unsure as to why there was such an obsession with avoiding an outdoor bayonet. However, satisfied with the result. Not really keen to mention the name of the builder, they have been great on everything (bar this now minor item) and we want to maintain our good relationship with them. Once again, thanks everyone! Cheers! Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9241 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6520 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 |
