This topic was brought up by Allan last time. I have talked to my builder, who said i just need to pay $50 to the brickie to put the anti-insect in the weephole in the whole house (i need to supply the stuff). I think it is a good deal.
ozn
Browse Forums Building A New House 1 Dec 14, 2007 1:33 pm This topic was brought up by Allan last time. I have talked to my builder, who said i just need to pay $50 to the brickie to put the anti-insect in the weephole in the whole house (i need to supply the stuff). I think it is a good deal.
ozn Re: Weep hole 2Dec 14, 2007 2:19 pm hey ozn, we saw this done on the Glenvill displays in the Chase. Very good idea and i suppose you would use the metal version in instead of the flimsy stuff??? How much do you need to supply the brickie? Do you know??? Re: Weep hole 3Dec 14, 2007 2:41 pm Dont know the quantity yet as the brickwork will not start next year, early february, perhaps. The builder estimated about 40 items. I will check when the brick work start and let you know.
Still dont know whether I willl use the weepa pest stopper or bushfire weepas. here is the link again http://www.weepa.com.au ozn Re: Weep hole 4Dec 17, 2007 11:15 am Too late for me now...
We are thinking of installing leave guard on the gutters, and might get them to put it on for us... Re: Weep hole 5Dec 17, 2007 11:24 am ahuang Too late for me now... Their website shows a range that can be used for existing weepholes, you can still put in the Pest Stoppas. http://www.weepa.com.au/peststoppa_info.shtml it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 5027 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 4116 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 3368 |
