Browse Forums Building A New House Re: Our build - back on track....bricks finished - yayyy! 342Feb 28, 2012 9:17 pm Don't know if I told anybody before, but we have Heller combined exhaust, light & heat. . . We have had to lock the ensuite window permanently open to disperse the steam. Re: Our build - back on track....bricks finished - yayyy! 344Feb 29, 2012 6:34 am Oh no, I thought heller were good... We are having powder ducted to outside and bathroom and ensuite ducted to roof - is this bad? Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 345Feb 29, 2012 6:43 am Not looking good for a roof today Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 346Feb 29, 2012 7:12 am Hey gogo, it's definitely a good way ofvdispersing the steam. We've got a combined light/exhaust in the WC and because there's no steam in there, there's no problem. There's also less of a problem with the light/exhaust/heat in the main bath, but that's about twice the size of the ensuite. I think our builder put in just a light and separate fan as standard, not sure if he knew better than us? Before we locked the window open a bit, we had them replace the shaving cabinet doors and hinges, the hinges had rusted and the mirrors had tainted. Phil went up in the roof and checked that there wasn't any insulation on top of the fan, but it was all clear. I think we'll eventually put in a separate fan. Maybe we should start a thread on this and see if anyone really knows? Hey Nina, I'm not sure that Heller are bad, maybe there's something wrong with this unit. All three of ours go into the roof, but we hardly ever use the WC anyway. We do, however, have the kitchen extractor fan and the clothes dryer ducted outside. Clothes dryer ducted outside was a requirement for me, as I'm English, and we all have it over there. . . No more dust and pet hairs all over the laundry wall, yeah! Re: Our build - back on track....bricks finished - yayyy! 347Feb 29, 2012 7:21 am Ah, you are a pommie too! We haven't got our dryer ducted, I did think about it (as thought we would have to have one of those horrible pipes sticking out the window if we didn't) but was told no need. I'm just thinking, I don't think we actually have a fan in the laundry at all....seems this is a mistake on our part? Re bathroom fan, heat lamp - if we have a fan over the shower and a separate heat lamp elsewhere we would be fine shouldn't we? Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 348Feb 29, 2012 8:49 am In our old house we had a top of the range IXL Tastic remote light/heater/fan combo which worked very well (even with the spa going) but did need cleaning every now and again as the grill cover got dirty. We now have a HPM light/heater/combo with 4 lights in the ensuite which seems to work okay although it's noisy and it doesn't look like it will require much cleaning - haven't done so yet! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In the main bathroom there is a 2 lamp jobby. Hope that helps .. For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Our build - back on track....bricks finished - yayyy! 350Feb 29, 2012 10:39 am [quote="gogo65"]It is something we have never thought of, quote] See ... attention to detail ... No I'm pretty sure ours is just into the roof space ... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Our build - back on track....bricks finished - yayyy! 351Feb 29, 2012 5:00 pm nina - we are getting external ducting (instead of exhaust fans). I can't remember where (but I am pretty sure it was on the Masterton thread) but I read about it being much better (but of course more expensive) to actually duct the exhaust as the fans are pretty weak. If you have a good window then that is a huge help, but for us we wanted ducting. Also, most builders duct (or have the exhaust fans) release into the roof cavity. This means moisture accummulates which is not a good thing if you have sarking (which we do). It is even worse if you have a flat roof (like we do). So for a number of reasons we want external ducting, not just exhaust fans, and not released into the roof. Still need to ensure we actually get what is in our tender, but DH was talking to builder about it this morning. SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Our build - back on track....bricks finished - yayyy! 352Feb 29, 2012 5:19 pm T, you're absolutely correct We have sarking in our roof & also have ducted fans to outside instead of the roof for that reason, if they're not, then the fans will create moisture in the roof & everytime someone has a shower moisture will accumullate . Re: Our build - back on track....bricks finished - yayyy! 353Mar 05, 2012 12:50 pm Thank you everyone for your fan/heat lamp feedback. Its still causing me a headache and I am probably worrying uneccessarily....but when faced with a decision I like to make things complicated for myself it seems! So - our electrician has recommended this from clipsal Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ but it only has a 125m3/hr airflow - whereas something like this has up to 550 m3/hr airflow Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Does anyone know if Mercator are a good brand? Ive never heard of them.... Also, in case you are interested, I just got separate quotes from CTC Communications for 2 alarm systems - and they are way cheaper than our electricain is quoting - more than $500 cheaper. So am going to see if we can use them instead.... Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 354Mar 05, 2012 12:54 pm springtime T, you're absolutely correct We have sarking in our roof & also have ducted fans to outside instead of the roof for that reason, if they're not, then the fans will create moisture in the roof & everytime someone has a shower moisture will accumullate . Hi Springtime - we have a whirly bird in our roof - will this help with the moisture (because we also have sarking)...? WH never informed us that ducting to the roof would be a problem from this point of view....but that doesnt mean anything!!! Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 355Mar 05, 2012 2:24 pm Hi Nina, That's what were were told by Costa the electrical people, they said it has to be ducted to outside because of the sarking & colorbond roof. If you had normal roof tiles, it wouldn't have been a problem. That's what were told anyhow, who knows who's right ? Re: Our build - back on track....bricks finished - yayyy! 356Mar 05, 2012 3:54 pm Double checked and all ok if you have a whirly bird apparently. Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 357Mar 05, 2012 4:51 pm Yep, I posted somehwere about the whirleybird (lost track of which thread ) My DH said the same thing, dont need ducting if you have a whirly bird, also we are having some new whirly bird (not released yet) that turns on automatically at a certain temperature and moisture level ((it has a thermostat thingy, which is plugged into a powerpoint in the roof) Re: Our build - back on track....bricks finished - yayyy! 358Mar 05, 2012 4:57 pm Very fancy GoGo! I did see your post about this, but thought it was ok because you had the fancy sensor whirly bird, so plsd to hear any old whirlybird will do! Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Our build - back on track....bricks finished - yayyy! 359Mar 05, 2012 5:14 pm Nina we were getting the plain old fashioned ones as well, until we met our new neighbour who is able to get us one of the new ones for less than the price of two old ones (only one is required regardless of roof size) because she works for whoever it is that makes them ??Boral nina marie Very fancy GoGo! I did see your post about this, but thought it was ok because you had the fancy sensor whirly bird, so plsd to hear any old whirlybird will do! Re: Our build - back on track....bricks finished - yayyy! 360Mar 05, 2012 6:59 pm Lucky you gogo, we got two at $450 each , & they're just the plain old ones, not the ones with the sensors you're talking about. Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9449 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28290 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6897 |
