Browse Forums Building A New House 1 Feb 05, 2011 8:37 am Hi All, Woke up today to a leaking roof in the ensuite.. The ceiling is wet at places.. and water dripping out of the light globe.. Who to call? Builder? Insurance Company? A tradesman at my own expense ? It is going to rain all day today/ tomorrow.. and the water is coming out of electricity point (light globe) Would appreciate advise from the experts plz. Cheers Re: 3 months in, and woke up to leaking roof ! 2Feb 05, 2011 10:10 am No expert, but fellow sufferer. Don't touch the light globe, for safety's sake switch off the lighting circuit breaker, use table lamps etc. your power sockets should be OK... call your insurance company, call your builder. Check gutters and valleys on roof for debris, as a last resort call a roofing plumber. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: 3 months in, and woke up to leaking roof ! 3Feb 05, 2011 1:46 pm Doesn't sound good, hope you get it resolved quickly. Don't bother calling insurance - unless the leak in the roof was caused by an insured event, it is not covered. Sounds more like the roofers didn't do a good job -> go talk to your builder. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: 3 months in, and woke up to leaking roof ! 4Feb 05, 2011 1:59 pm I assume you're in Melbourne? If so, it'll be a result of the excessive rainfall, not a building problem. We had the same thing happen just short of 12 months. When so much rain falls in such a short space of time, the stormwater system simply can't carry it away quickly enough. The spouting backs up and overflows back into the roof. If you have eaves, the effects may not be so bad (apart from wet insulation and soffits). If you don't have eaves, the water will find its way out via the lowest point, which is light fittings and fans. Some will soak through plaster. Some people have had ceilings collapse last night and this morning. Call your builder - you're due for a maintenance check anyway. You have to realise that they may not be able to come out immediately anyway. All builders' maintenance teams will be inundated with calls thanks to the rain, plus every plumber in Melbourne will be flat out, so don't be surprised if it's a while before there's any action. As long as the leaks are minor, the plaster will dry (ask what to do about the insulation) and any damaged paintwork can be touched up as part of your normal maintenance. This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28322 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Hey. Head to a metal and decide on which profile you will use first. Profiles with larger corrugations can greatly change the appearance of the color in different… 0 3385 |
