Browse Forums Building A New House 1 Feb 04, 2011 11:31 pm We moved in to our new home in June 2010 and our home is fairly new. We just noticed after todays wet weather in Melbourne, our roof is leaking in the garage and master bedroom... Dunno whom to call tomm. morning and whether builder will fix it? As it is leaking for abour 2 hrs now, not sure whether the roof will collapse... Are there trades people specialised in roofs and would the plumber be able to fix it? Have two little ones at home and bit terrified about his whole thing... Re: Roof Leak - Will the builders warranty cover it? 2Feb 05, 2011 12:45 am Take some photos and ring the builder in the morning Where you are coming from is where you are going to... Re: Roof Leak - Will the builders warranty cover it? 3Feb 05, 2011 2:44 pm ^ What Onc said. How bad are the leaks? If it's just a bit here and there near the walls, there's probably nothing to be done - one of those once-in-a-lifetime events. Best to call your builder anyway, to be sure. Check light fittings and fans, make sure there's no water coming through those. If there is, DON'T use them until you get them checked. Re: Roof Leak - Will the builders warranty cover it? 4Feb 06, 2011 3:13 pm Hi I have the same problem however my house is just over 4 years old... I got up on the roof and did not find any damage to the roof tiles so it seems that there is something wrong with the drainage. This is the first time we have noticed and wonder if this is under 7 year warranty... This is the probably the first time the house is subjected to so much rain... Any advice on whether this will be considered as a builder's warranty issue will be appreciated Thanks If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20236 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5084 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17324 |
