Browse Forums Building A New House Re: Arndell stage 11 2Jan 10, 2011 12:40 pm Hi I am building in Stage 11 but with Clarendon. Thought I should just introduce myself as we probably are prospective neighbors. I am at 1125 Rockpool road. Regards Samir Re: Arndell stage 11 4Jan 12, 2011 3:30 pm Hi Aysclick Thats good to know that you are not too far. We are building a single storey 27 square house called Oakdene 27. Its a corner plot so corner rendering would have to be done. Regards Samir Re: Arndell stage 11 5Jan 13, 2011 10:26 am Hi aysclick, You can check out the build journeys of Porter Davis clients Tracey and Wayne on the Porter Davis Blog if you're curious. They have provided some great insights and advice on their builds. Check it out here: http://blog.porterdavis.com.au/index.ph ... ground-up/ Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Arndell stage 11 6Jan 13, 2011 1:56 pm Team PD Hi aysclick, You can check out the build journeys of Porter Davis clients Tracey and Wayne on the Porter Davis Blog if you're curious. They have provided some great insights and advice on their builds. Check it out here: http://blog.porterdavis.com.au/index.ph ... ground-up/ Cheers, Jess. That would really help. I got a call from my Solicitor yesterday, Stage 11 is due to settlement in 26th Jan 2011. Good news. Re: Arndell stage 11 7Jan 14, 2011 12:57 pm Hi Aysclick Same here. I have rcvd the Transfer of Land doco from my solicitors and they say land is getting settled on Jan 27th 2011. Regards Samir Re: Arndell stage 11 9Jan 17, 2011 9:47 am Team PD Hi aysclick, You can check out the build journeys of Porter Davis clients Tracey and Wayne on the Porter Davis Blog if you're curious. They have provided some great insights and advice on their builds. Check it out here: http://blog.porterdavis.com.au/index.ph ... ground-up/ Cheers, Jess. PD Team, I'm building Kensignton 24 with PD, it has been removed from the home list, do you know the reason for doing this. Re: Arndell stage 11 10Jan 24, 2011 12:51 pm Hi aysclick, To help answer your question, the Kensington was one of the original Access designs when the home range was launched. It was a good selling design that we wanted to review and refresh early last year, the result of which is the new Cannonvale. I hope that helps answer your question, if you want me to put you in contact with some in sales that can chat to you about our range of home designs just let me know. Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 9090 1 4922 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 13492 |
