Browse Forums Building A New House 1 Jan 05, 2011 10:02 pm Hi, I am building a new home. Hi, Can someone advise about the pros and cons of the timber and steel frames in the house structure. Timber and wooden frames has been going on for decades but the steel frames are a new thing. So, what is the best option ?? Please advise. Steel frames may be termite proof but they may be susceptible to corrossion, are there any issues with the metallic contraction/expansion during summer/winters, which may adversely affect the house structure ? Please provide your views, they will be highly appreciated. Sanjeev Re: Which is better, Timber frame or Steel Frame ? 2Jan 05, 2011 10:09 pm Advantages of timber: • Well understood by builders. • Cheaper. • Easy to adapt or modify during construction or later. • Is a sustainable resource. • Lock away carbon. • Easy to fix fittings into. • Better sound and heat insulation. Advantages of steel frame • Cannot be attacked by termites or borers. • Prefabricated frames are lighter than timber. • Doesn’t have to be treated with chemicals. • Doesn’t rot. • Doesn’t shrink warp or twist. • Doesn’t burn. Inside a building rust should not be a problem, but just in case most steel frames are galvanised. All my houses up to now have had timber frames and I have been happy with the result so I would probably continue to use timber if I was getting someone else to erect it. If I was planning to erect the frame myself I would probably go for steel for the weight saving. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Which is better, Timber frame or Steel Frame ? 3Jan 13, 2011 7:40 pm As an owner who's had both (timber and steel framed roof) I'd strongly recommend going the timber route. Why? (In my experience) - insulation and other things like roof ladders are designed to fit in the widths of timber - tradesmen arent that keen on working in steel framed roofs (some have refused to quote once they know) - moving around the ceiling space is alot easier due to the narrower spacing (I'm 6'4" and I have trouble stepping between) Just my 2c worth Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 10540 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 6107 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 3028 |
