Browse Forums Building A New House 1 Dec 23, 2010 10:04 am Does anyone know how much each smartstart controller is? So it has to be turned on, wait 1 min or so, and then when you use the tap the hot water is there straight away... So with 4 bathroom for example, would you have one in each? How difficult are these to install? What exactly is required? Is there much point? I understand you save a lot of water by not opening the tap and waiting. But you still need to use energy to warm up the water :S Re: Hot water system and Smartstart 2Dec 23, 2010 10:07 am Advantages of a Rinnai INFINITY Smartstart Rinnai INFINITY Smartstart is Australia's first dedicated "Water Saving" Hot Water System. It has all the great features of a Rinnai INFINITY Continuous Flow with the added addition of a circulating pump to pre-heat the water in the pipes. This may take a minute or two depending on the size of your home, but will help you save literally thousands of litres of water over the life of your hot water system. Other features and benefits include: * High efficiency hot water with an in-built hot water circulation system * Pre-heats the water in the pipes before you turn on the hot tap * The Smartstart is an 'on-demand' pump system that only operates when required and automatically shuts off, further saving energy * It is activated in any room that has a Water Controller installed * Save literally thousands of litres of water often flushed down the drain * 12 year warranty on the Heat Exchange Re: Hot water system and Smartstart 3Dec 23, 2010 10:17 am Approximately how much does a thousand litres of water cost? I mean if I have to put a controller in each bathroom and then wait a few minutes anyway is there much point? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14074 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1361 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
