Browse Forums Building A New House 1 Dec 09, 2010 3:33 pm Hi gang, I am seeking advice from those who have a heat pump hot water system, as we have been advised that a solar hot water system might not be appropriate for our build. The problem being we have a long house (33m) with long lengths of pipework, we are on bottled gas and rainwater tanks are our only source of potable water. A heat pump with ring main has been recommended as an alternative that will avoid water wastage and ensure we have hot water delivered to both ends of the house. My question is are these units noisy? The pamphlets say they are no louder than an airconditioner, but as we live in a nice quiet bush setting, I am concerned we would hear the drone of the pump all the time. Anycomments/thoughts/experiences would be really helpful. Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Advice on heat pump hot water system 2Dec 10, 2010 1:05 am Hi, Some of them have been criticised over noise. There has been a recall on Rheem and Everhot too, for vibration. You could start here http://www.productreview.com.au/categor ... at_id=2085 Cheers Re: Advice on heat pump hot water system 3Dec 10, 2010 10:19 am Thanks Geoff, I am not liking the sound of these systems, but I fear we might not have much of a choice Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Advice on heat pump hot water system 4Dec 10, 2010 11:58 am We're putting the Rheem Heat Pump in but we don't have handover until some time in January so I can't give you any feedback on it. I've read some negative reviews which makes me nervous but then generally the only people who will review a product tend to be those with negative experiences. We're also on bottled gas and the heat pump seemed a more viable option than the others. Re: Advice on heat pump hot water system 5Dec 10, 2010 12:22 pm We had a heat pump in our spec - took it out and went for solar with gas boost. Don't know enough about them, and don't know anyone who has one to get feedback from. Have seen a few negative reports re noise. Would you have to run 2 units since your house is so long? Re: Advice on heat pump hot water system 6Dec 10, 2010 2:46 pm Thanks for your replies We would only have to run one as we will have a ring main in the ceiling with a pump circulating the water around the house. Its true zircon, often it is only the negative reviews that you see. It doesn't give a true reflection of the product, but is still something to consider. I might drop you a pm after Jan to see what your thoughts are, as we will only just be getting our slab end of Jan so have a little bit of time to sort it out. Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Advice on heat pump hot water system 7Dec 11, 2010 12:50 pm Couldn't you still have the ring main with a solar HWS? I can't give any feedback because we haven't used ours yet, but I got talked into a heat pump by the HWS salesperson. I'm really hoping what he told me re electricity savings with the heat pump is true! In our case, the additional cost of solar didn't pay for itself over the lifetime of the system, but I didn't factor in electricity price rises (and in hindsight I should have). As far as noise goes, they are meant to be the same as an external compressor for an airconditioner, so with careful placement of your HWS it shouldn't bother you. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12347 18 90420 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20219 |
