Browse Forums Building A New House 1 Nov 27, 2010 3:22 pm Hello, so we have our slab down finally, but having a look at where the plumbing pipes are, I cant see one for the water point for the fridge - should that be in the slab? Also I can see one for the dowstairs toilet but not for the hand basin, is it possible this doesnt go down through the slab? there are a couple of metres between where the basin is and where the wall of the house will be. Thanks in advance.. Re: Plumbing in slab for water point for fridge? 3Nov 27, 2010 3:32 pm Yep only the waste is through the floor. The water point will come down through the walls and be put in when the plumbers come before your plaster goes on. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Plumbing in slab for water point for fridge? 5Nov 27, 2010 8:35 pm there may also be a pipe (looks like a standard white PVC drain pipe) through the slab that links an island bench in the kitchen to a wall for services (ie. water/power). One end of ours is obviously under the island bench and the other end is hidden under a cabinet next to the wall in the kitchen. Its an idea to locate it so you know where it is for the future if you need it for any reason. I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 8126 Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9292 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6597 |
