Browse Forums Building A New House Re: Green smart house 2May 12, 2006 12:50 pm Mek,
Where abouts are you located? there is quite a few green smart display homes popping up through this country. I may be able to point you to one in your local area. If you are looking at water saving options please check out www.ecmanage.com.au Re: Green smart house 3May 19, 2006 10:06 am Hi Carl, thanks for your reply. I decided to educate myself and found lots of useful stuff on the Sustainable Energy Authority Victoria website and will be incorporating quite a few of things they suggest into our house, whether this will make our house green smart I don't really know (we're building considering orientation of the block, putting in double glazed windows, hydronic heating, solar panels, water tank, making sure windows are positioned and sized properly, etc). Re: Green smart house 4May 19, 2006 12:59 pm http://www.greenhouse.gov.au/yourhome/t ... /index.htm is worth looking at too The blog of my home being built: http://glint-bladesong.blogspot.com/ We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16088 I am planning to get shelly dimmers added to the non-smart switches that control light. It has no affect on the mechanical functioning of the switch and this is wired… 1 1390 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7020 |
