Browse Forums Building A New House 1 Nov 20, 2010 10:14 pm Hi, At the time of PCI, I called for independent inspector to inspect the home thoroughly. The inspector gave us the report and forwarded to our builder. One of the issue inspector discussed in the report was regarding tile expansion joints which he couldn't see. Builder responded on that issue that expansion joints are required in commercial buildings but not in residential homes. We asked for any documentary evidence which builder couldn't produce and now the builder has agreed that as per the building code the expansion joints are to be done. Builder says that "we normally do not do in homes but if you want we can do them for you but expansion joints can be different to your normal tile grout and catch dust etc etc" I need an urgent suggestion from you guys as to what should I do? Should I ask builder to go ahead and do the job or I can leave it as at the moment the tiling of our home is looking fantastic and we doubt that if builder put expansion joints it might not look as good as it is at the moment. How important the expansion joints are? Do rest of the builders normally put? Please reply with your view instantly as I have to get back to my builder urgently, Thanks, Re: Tiles Expansion Joints 2Nov 20, 2010 10:30 pm Our builder told us the opposite, that we had to put expansion joints in, and I have to look closely to see them. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Tiles Expansion Joints 4Nov 20, 2010 10:40 pm Yes they are really there the builder, tiler & myself went through the best place to put them, it basicly is a silicon line instead of grout. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Tiles Expansion Joints 5Nov 20, 2010 10:57 pm My builder put them in our plans for our house, I presume it is something they do with all tiled areas on houses they build. Building the Ascent 3000 with Burbank http://www.burbank.com.au/HouseDetails.aspx?houseId=82 viewtopic.php?f=31&t=39638 Re: Tiles Expansion Joints 9Nov 21, 2010 8:58 pm Lex When are the expansion joints required for tiling? I should really reword this question. What are the criteria and rules for placement of expansion joins in tiling? Under which circumstances one should install them? My signature is distracting people from my wise posts ... Re: Tiles Expansion Joints 10Aug 07, 2012 4:21 pm I'd like to revive this thread as we are currently trying to find a tiler to tile our living area and corridors. One of the tilers (the cheapest) has said that expansion joints are only used in commercial applications but he is prepared to put one in if we want. He also says that our tiles will crack because our slab has hairline cracks in it. The engineer has assured me these are only shrinkage cracks but we are on clay soil though the slab was put down last November. Does anyone know if this tiler knows what he is talking about or should I avoid him? Re: Tiles Expansion Joints 11Aug 07, 2012 4:33 pm The tiler that I use, said that you need to have expansion joints every 5m of tiles. Some tilers are very pedantic about this and will actually cut the tiles at 5m and make sure there is a joint, where my tiler waits until the next full tile and will put the expansion joint in. They are silicone and are slightly different colour than the grout, but you can barely see them. Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 Re: Tiles Expansion Joints 12Aug 07, 2012 4:41 pm Hi Jen1977, Thanks for the prompt reply. I've just spoken to the second tiler on my list who also says we don't need expansion joints! Our living area is 5 by 10 though there is a kitchen island and cupboards around the place but, by your tiler's recommendations, we should have at least one. On a more hopeful note, this one didn't tell me my tiles are bound to crack whatever he does. Re: Tiles Expansion Joints 13Aug 07, 2012 4:56 pm Expansion joints can be closely matched to the colour of your grout. My Builder put them in most of the corners in the wall tiles and the floor tiles as well. After Handover I put some myself specially where the tile connects with Kitchen bench top (We extended our kitchen benchtop) Orchid 4200 with Burbank: Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=53034 House Built in 7 Months and 2 weeks Re: Tiles Expansion Joints 14Aug 07, 2012 9:00 pm Tiler number three does do expansion joints but his is the more expensive of the three quotes - $4015 for laying 64 square metres of ceramic tile 45 x 45 - we supply the tiles. Is this a reasonable amount to ask? Re: Tiles Expansion Joints 16Aug 22, 2012 12:13 pm Every 5-6m in both directions without compromise ! I've replaced and seen numerous tiling jobs where there were lots of cracked or lifting tiles because a lazy tiler or builder has failed to do this. One of the worst was at a local F...... Furniture store where there were no expansion joins at all for thirty metres in either direction. Consequently the tiled floor cracked like hell and it all had to be ripped up and replaced. And no, it is easy to hide the expansion join so that it looks exactly the same or very close to all the other tile joins. Sometimes there will also be a construction join in the slab to allow for expansion also which must not be tiled over although not seen a lot on most residential slabs. Stewie Re: Tiles Expansion Joints 17Aug 22, 2012 3:41 pm doublej2500 Expansion joints can be closely matched to the colour of your grout. After Handover I put some myself specially where the tile connects with Kitchen bench top (We extended our kitchen benchtop) how will you do it after handover. Do you mean you will take out grout and fill that with silicone etc. Re: Tiles Expansion Joints 19Sep 02, 2012 8:27 pm Similar to the grout line. You can have them "stuffed" with some special filler (can look messy if they are made too wide) OR you can have those nice fancy ones that you see in shopping centres' tiling. BTW, we don't have them ... if the slab starts cracking that much, tiles will not be my top priority My signature is distracting people from my wise posts ... Re: Tiles Expansion Joints 20Sep 07, 2012 12:40 am doublej2500 Expansion joints can be closely matched to the colour of your grout. My Builder put them in most of the corners in the wall tiles and the floor tiles as well. After Handover I put some myself specially where the tile connects with Kitchen bench top (We extended our kitchen benchtop) what did u fill in expansion joints? Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7465 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7777 Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2781 |
