Browse Forums Building A New House Re: Is this quality build ? 21Nov 28, 2007 4:17 pm I have similar issue as mentioned in my blog:
http://building-our-first-house.blogspot.com/2007/11/progress069-new-issue-with-gaps-above.html According to our supervisor it will be covered later. I will still leave it as open issue for tracking purpose until it's been fixed. Re: Is this quality build ? 22Nov 28, 2007 4:45 pm We follow your suggestion to put our concern in writing and cc a hard copy to cs department this morning as we know they are holding a meeting every Wednesday. We ended our letter by saying if they chose to ignore our concern, we will refer the matter to the BACV. The Regional Manager rang us back a couple of hours later advising they will look into the issue. This is a good sign. Will keep you guys posting and once again, thanking all for your input.
ben Re: Is this quality build ? 23Nov 28, 2007 5:21 pm ![]() ![]() it is a window and not a door right? Are the Tolerances different for windows and doors? They are pretty much the same visually ~60-65cm, yes just less than a brick high. In the drawing I posted earlier, if i draw a horizontal straight line over the top of the laundry door, the bathroom window (immediate left of door) is lower than the door and the other window. What on the house now: top of the three mentioned openings are same height. ![]() The builder argument is that the only spec is 545 (underside of window frame to floor) they have followed it. ![]() Re: Is this quality build ? 24Nov 28, 2007 7:09 pm melbman
doors are generally diffrent heights to windows so brick courses may not line up with windows to doors in height as for tolerances for doors, when i looked into it i only concentrated on windows not doors if you have a look at the link posted previous it may or may not mention it if not goto the main website and you should be able to find the answer if not call the tech section of building commision Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Is this quality build ? 25Dec 20, 2007 1:02 am ![]() We follow your suggestion to put our concern in writing and cc a hard copy to cs department this morning as we know they are holding a meeting every Wednesday. We ended our letter by saying if they chose to ignore our concern, we will refer the matter to the BACV. The Regional Manager rang us back a couple of hours later advising they will look into the issue. This is a good sign. Will keep you guys posting and once again, thanking all for your input. ben Sorry for being offline for so long mostly because we allowed fair and reasonable time for the builder to respond. There's a top person of the office reckons April 1st is around the corner. What happens is nothing less than a joke. We wrote to them very clearly that the infill on our window is not what on the display home we were walked through and made our purchase decision on. We want same finish as displayed. After playing games with us on which display home and request of photos the said display home. They produced photos of an window with an infill of one of their other display home that we have never been to. We produced a photo of the same window at the display home we went to. The regional manager came back to say that they don't build as per display home only per contract. ![]() Our building consultant help drafted a letter saying that as per the Domestic Building Act section 43 http://www.legislation.vic.gov.au/Domino/Web_Notes/LDMS/PubLawToday.nsf/a12f6f60fbd56800ca256de500201e54/1331B500B20CD42DCA257302001ED7D0/$FILE/95-91a063.pdf that the builder must construct as per display home unless it is specifically spelled out in the contract. (There is nothing as such in ours.) We might be misled under this Act otherwise. We then had a on site meeting with the construction manager to discuss the issue and to provide us with a letter of response. He discussed that whilst an custom made window to fit is an option it is not economical for them to do and they won't do it. They propose to raise the bathtub and window by 60mm or so to eliminate the external infill whilst keeping the bathtub level to the window base to be the same as the display home. The letter was withheld. He had a meeting with the regional manager then emailed us that they decided to leave it as is or replace the timber with an aluminum one. They explained they decided so based on their misquote of their discussion with our building consultant that we told him that we are happy with the aluminum infill solution. We have repeatedly expressed in the meeting that we want the same look as per display home, no infill. They are putting words into our mouth and then made the decision. How professional is that ? ![]() Called our consultant re: the conversation with them. He told us that he understood that they will raise the bathtub & window and that's pretty much the end of it. He was surprised to see the email they sent. He will give them a call to sort things out. It will be interesting to find out what's next. Consumer Affairs ? Yes we will. Re: Is this quality build ? 26Dec 20, 2007 7:17 am Oh Ben, that's horrible news. Have you had an independant inspector come and have a look at it? I would, then you have a professional backing you up that it is not good practice. With all this paperwork going back and forth, wouldn't it be easier for them to just put a new window in?? Surely it would be less hassle to them. They're making enough off the whole project I can't see how one window will break the bank.
Thanks for keeping us posted. I'm interested to see what happens next. Jet Re: Is this quality build ? 27Dec 20, 2007 9:39 am In our case, we did ask our own inspector about the gap above external laundry door & window (all other windows are fine). Our inspector said that was normal and it will be covered... Re: Is this quality build ? 28Feb 08, 2008 11:59 pm ![]() Oh Ben, that's horrible news. Have you had an independant inspector come and have a look at it? I would, then you have a professional backing you up that it is not good practice. With all this paperwork going back and forth, wouldn't it be easier for them to just put a new window in?? Surely it would be less hassle to them. They're making enough off the whole project I can't see how one window will break the bank. Thanks for keeping us posted. I'm interested to see what happens next. Jet Just an update for those interested. We have a bit of a win !! Here's a brief of events: Lodge a formal complaint to BCAV (Consumer Affairs) just before xmas/new year break. 2 weeks later received letter of receipt from BCAV. Few days after that we received a call from regional mgr ![]() BCAV is the way to go. Cost us $0. Re: Is this quality build ? 30Feb 09, 2008 7:10 am Well done, I'm glad to see there was a way around it. Thank you for your reply. The square set is where the wall paint meets the ceiling paint, the sheen is the light reflecting the poor cutting in. On some parts of the… 4 1839 An Not sure where you are up to in the build but if you are mid way and they install a new footpath now it could be damaged again. What I did with mine was to install a… 3 5336 ![]() Great question about home loans and savings. You have a solid plan for your renovation funds, but you want to ensure you understand your loan and offset account details. 10 29790 ![]() |
