Browse Forums Building A New House Re: help with plan please 21Nov 07, 2010 3:14 pm Hi Kiwi,my friend say same about sliding door to outside.I don't like them,we are in cattle and horse country to many flies.Just me to slow in closing sliding door,not sure if I will have french doors in MB.Yes David 242 is great.Had a look at your plan very nice family friendly,not like mine Re: help with plan please 22Nov 07, 2010 3:18 pm Hi Laurend,Yes MB needs to be smaller,sitting room will not get used (I know) I have some antiques I want to display Re: help with plan please 23Nov 07, 2010 11:05 pm Kiwi, I had a look at your plan on page 9, but aren’t you building it at the moment. pattycake4, good to hear you are thinking about your planning. Remember its cheaper to move it on paper than change it when the builder is hitting nails. I have just a few more comments. 1. Consider the access to the outside. A flyscreen on a sliding door will keep the flies out. Where will the swing door sit when it’s open. 2. Are you considering the TV between the two windows. If so will you be able to see the TV whist working in the kitchen or in other areas of the meals/kitchen space. 3. Will there be other furniture in the meals room other than the kitchen table.(and chairs) 4. Why not open your study into the entry with the door to the top of the room, just below the storage cupboards you can now increase, door of study cupboard closer to the garage wall. This way you will use your entry on a more regular basis, and therefore enjoy the antiques in the sitting room more. The hall furniture can be moved towards the front door. 5.If you flip over the bath/laundry move the laundry door to the short corridor opposite the bathroom door. This will further clean up the hall way walls, more space for nice pictures. Oh check the layout of the laundry with the door move to ensure you don’t loose storage or bench space. 6. Master bedroom. Is it possible to add some windows to the wall opposite the door to both add extra natural light to the room as well as allow for cross ventilation? A room with one window doesn’t allow for air movement on hot nights like a 2-3 window room can. 7. I’m not sure what “RA” means, but is worth using a cavity slider in the hallway rather than a swing door so it is not exposed when your not using it. I would really be interested to see you plan with your furniture layout indicted, also this will allow you to have an understanding of how the layout works before you commit to building. Cheers. Re: help with plan please 24Nov 08, 2010 5:05 am we have started the earthworks, but no slab/ frame as yet and the builder is building it (not pre nailed etc) so any minor changes right this second, can be done..but you have to be quick!! I was thinking that if the sitting room is for antiques and not really used...why dont you combine an antique room with the study (make it slightly bigger but not as big as the 2 rooms are now) ...and use the left over space to make the theatre bigger. If you shrink the master by 100mm each side..add that too. might mean changing your plan a bit, but keep the sq mets the same. just tweak your rooms sizes. crazy having alarge unused room, and a study that could handle the antiques, and a theatre that is too small... but I do like your plan. just some thoughts. Re: help with plan please 25Nov 08, 2010 3:37 pm Hi David 242 and Kiwi,I will be taking your suggestions with me on my next visit to see draftsman RA is return air. Re: help with plan please 26Nov 08, 2010 9:21 pm pattycake4, would you be able to explain how your return air works. I dont see how a single storey house requires a riser for this. When is your unit positioned what system are you installing. Also if the RA is on the living side of the door what system is on the bedroom side of the door. Re: help with plan please 27Nov 10, 2010 9:13 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just posting the plan on this page to make it easier to reference the suggested changes.... Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: help with plan please 28Nov 10, 2010 9:18 pm If it was me, I would be changing the position of the door from the meals to the outside ( I'd be changing that window/door to a triple slider inserted where the current window is...as mentioned above, a sliding flyscreen keeps the insects out.. ), then you could run the island bench much closer to the wall-giving really good bench space. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: help with plan please 29Nov 10, 2010 9:41 pm There are some really good suggestions made-eg the centralisation of the plumbing in laundry etc. RA is required in single story dwelling for ducted heating/cooling. BTW- you can get auto closers for sliding doors! I would move the island bench so that it had 1200mm between benches (instead of 1500mm) and then towards the back wall. I'd also consider entering through the study from the garage-then you can use the current hallway space for storage. By swapping the entry and sitting, you can add a nib wall alongside the appliances in the kitchen-which then gives you a choice of where you want the entry for the sitting to be... I've had a play on paint-so it's rough, but gives an idea.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: help with plan please 30Nov 11, 2010 6:15 am ooow, you have given her a bigger study! nice. and you now dont see the kitchen as you enter cos of the wall with the fab new mirror on with a table for keys/ phones and a fabulous lamp on, as a lovely welcome home! not like this.(bit old fashioned, and no fab mirror or lamp) ..but you get what I mean Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think the sitting might be bigger too? anyway, looks good. Re: help with plan please 31Nov 11, 2010 6:17 am maybe use one of your antique tables and lamp on that wall...whaoaoao! Re: help with plan please 32Nov 11, 2010 8:25 am Could somebody post a link to a AC system that requires the RA riser. Does the system drawing the air from the floor level for return. Once i understand this it maybe clearer. Re: help with plan please 33Nov 11, 2010 8:14 pm And to think I had to pay a Draftman,you guys are GOOD.Dee so much knowledge (4 builds)Kiwi have the perfect table with mirror and all.I can see light at the end of tunnel.Now all I need is a sold sticker on my for sale sign This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11293 we need accurate dimensions as well as the number of bedrooms and bathrooms needed etc to make specific suggestions but, based on estimated rooms sizes, it could be… 1 579 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17293 |
