Browse Forums Building A New House 1 Oct 12, 2010 9:30 pm We want to add an Alfresco to our house plan. We are building with PD and have completed tender but not signed the contract. We got a quote for a 8000mm wide x 2750mm deep for about $9609.00. Does this sound too much or is this reasonable. Or should we consider building a Pergola after completion of the house. Thoughts on Alfresco vs Pergola would also be much appreciated. Tarneit : The Reserve Re: Alfresco cost 2Oct 12, 2010 9:35 pm Assume that the alfresco is under the roofline and includes windows / sliding doors? Re: Alfresco cost 4Oct 12, 2010 9:49 pm It's a large area. The price you mentioned is about equivalent to a garage extension of the same size. It will add value to your home but at a slight premium. It's good and much better than a pergola if you can afford it. Re: Alfresco cost 5Oct 12, 2010 9:54 pm Thanks Eve, yeah can definitely afford it but wanted the general opinion. Cause during the Sales quote stage they said 5400$ for a similar area. Again they might not have taken into consideration the slab costs etc. Tarneit : The Reserve Re: Alfresco cost 6Oct 12, 2010 9:58 pm You may be right there. It's one of things that you really have to do now as opposed to after a house is built. Re: Alfresco cost 7Oct 13, 2010 10:24 am Sounds about right. I built with Henley and to add an alfresco on the rear @ 3500mmx5500mm under roofline and slab was $8500. Building Charleton 283 with Henley. Stage 11 - Alamanda Point Cook Build contract signed 22nd September 2009 Land settled - 17th May 2010 Site Start - 25th June 2010 Re: Alfresco cost 9Oct 13, 2010 1:11 pm Thats good- ours was just over 7000 just for the roof- 5.5m x 3.5m Built our Granton in 2010 Handover December 3rd- wooohooo! Now the hard work has began.... Retaining walls and landscaping Re: Alfresco cost 11Oct 13, 2010 9:02 pm Thanks for all your replies it has helped immensely and we have decided to go for it! Lunchtime - Are you happy with your dimensions ours is very similar we thought it a bit too narrow but we can only perceive what it looks like in our minds for now Tarneit : The Reserve Re: Alfresco cost 12Oct 14, 2010 5:40 am Hi Rramesh, we have not moved in yet - still a month or two off. But we saw it on a PD Display home at Innisfail estate. We will be extending the paving like they have to open up the area more. PD do have a 'grand alfresco' option - if you have the land it might be worth looking at. Also remember anything under your roofline counts as part of the 'squares' of the house, so i would say its worth it rather than a pergola. When its time to sell, my 29sq home is acutally just over 32sq Re: Alfresco cost 13Oct 14, 2010 6:52 am Lunchtime Also remember anything under your roofline counts as part of the 'squares' of the house, so i would say its worth it rather than a pergola. When its time to sell, my 29sq home is acutally just over 32sq Fuuny though. In the U.S. It's not counted. A 30sq home here is like 20. Re: Alfresco cost 14Oct 14, 2010 9:00 am You'll be glad you've gone for the alfresco definitely - they add a substantial cost, but also substantial value. It probably makes sense to add a pegola if moving into an existing home, but if building new, nothing beats the integrated design of what the builder will provide for you in the end. I extended my roofline only by about 2.25m + 450mm eves and the concrete beneath by about 3.25m (wanted some shade but also some sun to come in) and althought it's early days in the build, I think the pegola route would not have been as satisfying - might be a tad cheaper, but probably false economy... and do you really want more tradesmen in after handover? I don't think so! Building with the Big M, Sandarra Settlement July 16 Site Scrape Sep 22 Slab Oct 12 Framing commenced Oct 13 Build thread: viewtopic.php?f=31&t=39517 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4194 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4890 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1665 |
