Browse Forums Building A New House 1 Nov 15, 2007 9:24 am The following information is culled from
http://www.omara.com.au/Our_rates.htm --- Although our rates and charges may vary depending on the project the following is a list of our standard rates and charges; DESIGN STAGE All building tenders.... No charge Professional advise or site inspections... No charge Prepare all documentation for council approval.......... P.O.A CONTRACT CHARGES These are the charges which are usually included in your building tender. These costs are as of October 2006 and are subject to industry rise and fall. They will be fixed at the time of contract signing. PIERING Piering will be required for any poor soil conditions, any foundations within the zone of influence of sewer mains, through any filled ground or for any poor or uneven soil conditions Any concrete piering will be charged at the following rates; Concrete piers 300mm diameter....... $40/m Concrete piers 450mm diameter....... $60/m Concrete piers 600mm diameter....... $80/m Concrete piers 750mm diameter..... $100/m Concrete piers 900mm diameter..... $150/m A minimum charge of $1,500.00 applies to any drilling rig concrete piering. NO minimum charge applies if pier holes can be drilled by bobcat on site Mass concrete piers dug with excavator and poured as part of standard concrete pour is charged at the rate of $200 per m3 of the extra concrete required ELECTRICAL POWER Single or double power point...... $61.00 External weatherproof power point..... $120.00 15/20amp power point (eg Spa)..... $225.00 LIGHTS Light point (batten holder only)...... $59.00 Low voltage gimble downlight...... $69.00 Two-way light switch...... $77.00 Dimmer switch $69.00 External bunker wall light $85.00 External wall light (supply by owner)...... $20.00 Fluro light 36 watt twin...... $68.00 Ceiling fan with light (white)..... $185.00 Exhaust fan (no ducting)...... $85.00 Exhaust fan ducted (max 12m duct)..... $460.00 Exhaust fan light / fan combo..... $205.00 Bathroom 4 heat IXL..... $365.00 Install light fitting supply by owner $20 ea. OTHER ITEMS TV point in RG6 for digital / Foxtel $80.00 Telephone point $80.00 Smoke detector...... $145.00................ Air-conditioner circuit 20amp 1 phase..... $225.00 Extra underground mains (meterbox, water tank, septic tank)....... $48/m Points are allowed to be installed pre-gyprock in roof or wall cavity with good access. Any poor access site, chasing of brickwork or conduits for face mounting on existing brickwork will incur additional charges All fittings are as per electrician’s sample BRICKWORK Extra brickwork (large areas)... $900/100 bricks laid Bagging brickwork...... $15/m2 Brick headers....... $25/m Install vents.... $20 each Brick cleaning... $50/1000 bricks Supply sand, cement, lime & ancillaries.. $100/1000 bricks Concrete blocks..... $4 each Supply bricks or blocks.. at builder’s discounted rates STRIP FLOORING Labour to lay 80mm wide strip flooring on existing floor joists...... $35/m2 Extra labour to lay 133mm wide strip flooring over cost above $3/m2 Extra labour to supply & lay battens to concrete slab...... $15/m2 Floor sanding of new strip flooring...... $28/m2 Minimum charge for floor sanding (areas under 27m2)..... $650.00 Cypress pine strip flooring 80mm finish (Supply only) $35/m2 Blackbutt strip flooring 80mm finish (Supply only) $70/m2 Jarrah strip flooring 80mm finish (Supply only) $80/m2 Bluegum strip flooring 80mm finish (Supply only) $75/m2 Tassy Oak strip flooring 80mm finish (Supply only) $65/m2 Spotted gum strip flooring 133mm finish (Supply only) $85/m2 All select grade Mixed hardwood 133mm finish UTILITY GRADE (Supply only) $45/m2 SHELVING & JOINERY Extra vertical or horizontal shelving to owners design Melamine shelving up to 600mm wide $48/m Melamine shelf with hanging rail ...... $65/m CERAMIC TILING Porcelain tiling in lieu of ceramic..... $10/m2 Border tiling wall or floor...... $20/m Additional tiling $45/m2 GARAGE DOORS The additional price for high-lites to sectional panelift garage doors is $450.00 plus GST each of pattern design to be selected from samples provided by builder The additional price for automatic control, including power supply is $750.00 plus GST each. SHOWER SCREENS Upgrade shower screen to semi-frameless shower screen..... $200.00 Upgrade shower screen to fully-frameless shower screen.. $1,800.00 MACHINE HIRE DROTT BULLDOZER. $120/hour EXCAVATOR... $90/hour BOBCAT... $70/hour TRUCK HIRE... $80/hour Minimum charge of 4 hours applies Float charges of $150 for drott & excavator, $80 for bobcat applies PLANT & EQUIPMENT MINISKIP – 2m3 $150.00 MINISKIP – 4m3 $300.00 MINISKIP – 2m3 for AESBESTOS FIBRO..... $300.00 LABOUR RATES The following labour rates apply to any variations that cannot be quoted as a fixed lump sum (e.g. replacement of white ant damaged timber). Please note that this is rare as most variations can easily be quoted as a lump sum BUILDER ON SITE... $80/hour FOREMAN... $60/hour CONCRETOR... $45/hour CARPENTER... $50/hour CARPENTER APPRENTICE... $25/hour BRICKLAYER... $50/hour BRICKLAYERS LABOURER... $25/hour ELECTRICIAN. $50/hour PLUMBER... $50/hour PLASTERER... $45/hour CEMENT RENDERER... $45/hour CERAMIC TILER... $50/hour METALWORKER $50/hour ROOF TILER... $45/hour LANDSCAPER. $40/hour KITCHEN MANUFACTURER ON SITE... $50/hour PAINTER... $45/hour LABOURER... $20/hour CLEANER... $25/hour BUILDER’S PERCENTAGE A builder’s percentage of 20% applies to all of the costs listed above GST GST of 10% applies to all of the costs listed above Re: A website on building cost indication 2Nov 15, 2007 12:30 pm Excellent stuf OzNow.
And as an aside. I was talking to a customer the other day and an Electrician, plumber or anyone of skilled trades in Darwin at present are around the $125 per hour amd an 8 weeks wait. ![]() Such is the mining boom of WA - they all gone west ![]() Steve Re: A website on building cost indication 5Apr 03, 2009 12:20 pm Hey, thanks for the effort to post all of this! I am not sure if I agree with the pricing, seem quite cheap, but the list isworth documenting. Maybe as building has fallen flat on its face this year, these are the prices people are paying??? Re: A website on building cost indication 6Apr 03, 2009 1:38 pm hi thanks for the post, but unfortunately i think pricing from oct 06 has gone up a bit. But it is great to get an idea My question, why dont we hassle the land developers to lower their prices, we seem to pay so much more for the land in NSW rather then the house, in melbourne is the other way around Re: A website on building cost indication 7Apr 03, 2009 4:59 pm ![]() thanks for the post, but unfortunately i think pricing from oct 06 has gone up a bit. But it is great to get an idea my bad .... i was searching through the archives and found this original post prompting me to check the builders website ....which has updated prices! here . http://www.omara.com.au/design,_supplie ... links.html i was just interested in hearing from anyone dealing with this firm !! 1 12146 Hi, does anyone have a clue how the Brisbane Development website work in terms of how uptodate the dates on it are (developmenti.brisbane.qld.gov.au). I transfered… 0 2490 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 1405 |
