Browse Forums Building A New House 1 Nov 13, 2007 11:18 pm We are building on a block wherey by the lot behind us (call it Lot X) is about 1.5m higher than ours. A retaining wall separates us both (as per normal).
We noticed some weeks ago that vertical and horizontal cracking appeared along the retaining wall in lengths of up to 2m. Also one of the large blocks making up the wall had moved forward (separated). This had all happened following preparation of Lot X. We queried the land developer, and on sending out the developer manager confirmed it was as a result of 'raking' being undertaken on Lot X. They (land developer) then mentioned that it would be up to us to chase up the owner of Lot X to action their builder in repairing the wall. Now I can see this developing into one of those 'issues' only resolved by taking someone to court. We don't know if we are overreacting, however the prospect of somebodies house ending up in our small (3m) backyard terrifies us. We have initiated contact with the owner explaining the situation and requesting action/acknowledgement with a copy being sent to their builder. We had contacted their builder some weeks ago indicating our intentions to which their reply was "We'll look into it" and (surprise, surprise) haven't heard anything since. Am I just being a first home owner worrying/expecting to much? Re: Retaining Walls advice 2Nov 14, 2007 4:32 am You're not over-reacting. It's your right to protect the integrity of your property, and if their work damaged your wall, it's up to them to repair it.
Keep pushing the builder, it's not really the owner's fault. Re: Retaining Walls advice 3Nov 18, 2007 10:53 pm Make sure you got all details all written down...
Have a look at this tips of mine (thanks to stonercutter1309 for providing the information) "How to record issues about your construction, in case you need to bring your builder to court" http://building-our-first-house.blogspot.com/2007/09/tips016-how-to-record-issues-about-your.html Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15499 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6887 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45700 |
