Browse Forums Building A New House 1 Sep 10, 2010 1:07 pm Dear All,
Am new to this Website. I have recently put in a deposit for a block of land in Epping North. Eucalypt Estate by Stockland. My lot size is 694 m2 29.84m2 frontage -- 29.32 m2 right side and 17.8 m2 in backside. My block is not a perfect rectangle block. 01) Stocklands has promised me of a settlement date of April 2011. Do you all think they will be able to deliver it on time? 02) Not sure What sort of a house I can build on my land? Many builders knock me back saying I cannot build a decent size house ( including PD, Mettricon..etc..,) My friends have told me to go for a private builder who can custom make a design that will fit in my block. 03) Not sure if there is any form of Internet ( ADSL2 / FIBRE optic) and Foxtel connections in my estate. Any thoughts will be welcomed and I would like to hear back from people who have purchased land in this estate. Regards Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 3Sep 10, 2010 10:13 pm Stage 1C . Bangalay rise (previously named Esperance Rise) Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 4Sep 11, 2010 12:18 am I've spoken to a few people who are building in Mernda Villages (also Stockland) who have said that they're pretty good with settlement dates, not massive delays like some builders. Obviously will vary from estate to estate however. No clue about house sizes, ours was a house and land package! But maybe browse through the main builder websites as a lot of them will give you minimum block dimensions required and see how that goes? viewtopic.php?f=31&t=37229 - our Iris 4! Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 5Sep 11, 2010 8:30 am Settlement might go ahead on time, or it might not... That isn't a lot of help, but every stage can vary, depending on dozens of factors. Ours ran three months behind schedule. The next two stages were right on time. Luck of the draw. At over 600m2, your block is certainly BIG enough, but being an odd size, you'll be restricted as to house design. If you want something reasonably big, you may either have to go for a double storey with a small footprint or a custom design. Keep looking, talk to lots of builders and see what you can find. Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 6Sep 12, 2010 4:30 pm THANKS 4 ALL UR REPLY... am impressed with Atrium 30 Square metre house from PD. may be i will try to go to the private builders for a custom plan coming weekend. Regards, Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 7Sep 13, 2010 10:32 am Am also tempted to go for a small house now and borrow less on a home loan.... 20 sq.M house will be a big house for me .... Is it possible for me to build a small house and have a good sized garden? Not sure about what section 32 of the contract says .....Is it must for me to use 80% of land for building purpose and only leave 20 % land for garden .... need some advice please..... Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 8Sep 14, 2010 10:20 pm if it does not rain much the settlement dates might b sooner......its delayed only cause of the rains..... guys any idea what stage r the pine park drive blocks in ? Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 9Sep 15, 2010 9:25 am Do you need to build your house so the long side faces the front? It sounds like it from how you've described your block. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 10Sep 15, 2010 9:38 am Yes thats right BTHERL..... I still need to study my section 32 properly for the frontage and the where I can have my entrance and what style of house I can build on the land..... Good thing about my land is it has no easement...... Where did you build your house. RIVA is one of my favourite model... Its a beautiful house. How was ur experience with Met**con? Thanks 4 ur response ...looking forward to keep in touch with you... Have a nice day... Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 11Sep 15, 2010 10:39 am Harry, what are the total dimensions of your block, as in the length of all boundaries? Can you put a pic up so we can see the shape? I built with PD, but almost built with M'con. M are more flexible if you really need to alter the floorplan a lot, PD are a bit more restrictive with floorplan changes. If you put up a pic of your block and some of your requirements for your house, we may be able to give you some ideas. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 12Sep 15, 2010 11:57 am THANK YOU - JOLES I have received exact dimentions of my lot. I have attached it on this thread.... Many builders consider it as an awkward shaped lot and I cannot fit a decent size house. I love lot of houses but I think I can only build a 20 SQ.M house in this lot.....SAD..... Dimentions of my lot - Bangalay Rise - Eucalypt - Epping - Wollert - Stockland Frontage = 29.02 right side = 29.24 left = 29.89 back side = 17.88 The above readings are the lot facing the street. Cheers Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 13Apr 16, 2011 3:49 pm Hello my name is Will Jesser and my business called Tvtel does FTTH wiring for new homes. I believe Eucalypt will be an Optic Fibre Estate controlled by NBN Co. If you would like a quote for a wiring system for you new home, or more information please contact me. Regards Will Jesser Tvtel P/L 0400 690 168 www.tvtel.biz williamjesser1@optusnet.com.au Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 14Aug 21, 2011 9:07 am Hi All, I had a bad luck with my block 189 Bangalay rise. Just couldn't settle it due to unforeseen cirumstance. Buut I manage to put in a deposit for 314 Pine park drive . People say - Pine park drive is a busy street and it will be with lots of traffic and resale value will be less due to lack of privacy. Dont know if its safe for kids tooo let me know your thoughts on this...don't know about the Rock under the block too.. right now shopping for house deals and trying to get a contract from builders. Thank you. Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 15Sep 29, 2011 5:50 pm hi harry....whom r u building with ..... I had my Front Windows broken by vandals yesterday ...no clue what to do abt it any suggestions hariharansivakumar Hi All, I had a bad luck with my block 189 Bangalay rise. Just couldn't settle it due to unforeseen cirumstance. Buut I manage to put in a deposit for 314 Pine park drive . People say - Pine park drive is a busy street and it will be with lots of traffic and resale value will be less due to lack of privacy. Dont know if its safe for kids tooo let me know your thoughts on this...don't know about the Rock under the block too.. right now shopping for house deals and trying to get a contract from builders. Thank you. Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 16Mar 19, 2012 9:30 pm tanmax hi harry....whom r u building with ..... I had my Front Windows broken by vandals yesterday ...no clue what to do abt it any suggestions hariharansivakumar Hi All, I had a bad luck with my block 189 Bangalay rise. Just couldn't settle it due to unforeseen cirumstance. Buut I manage to put in a deposit for 314 Pine park drive . People say - Pine park drive is a busy street and it will be with lots of traffic and resale value will be less due to lack of privacy. Dont know if its safe for kids tooo let me know your thoughts on this...don't know about the Rock under the block too.. right now shopping for house deals and trying to get a contract from builders. Thank you. Harry Re: EUCALYPT estate EPPING NORTH by Stockland - Land settlem 17Oct 24, 2013 9:51 am Whos the best NBN provider for eucalypt.. 9/4/14-Site Start 9/5/14-Slab 16/5/14-Frame 21/5/14-Roof 31/5/14-Bricks 6/6/14-Plaster 14/6/14-Fixing 19/7/14 -Flooring 8/8/14 - Keys http://newnestinmelbourne.blogspot.com.au/ Hi i am looking to buy an investment near by North Rothbury. How is this area? is there schools inside this estate? please advice good builders around that area to buy… 0 3021 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18200 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 22814 |
