I was sure I found something not long ago, but google doesn't seem to be my friend today.
Stacker wardrobe doors?
http://www.bradnams.com.au/index.pl?pag ... cts&cat=11
ETA: If the link doesn't work, go into the Queensland region, then Products and then into the Wardrobe Doors section.
This sort of thing? ETA: If the link doesn't work, go into the Queensland region, then Products and then into the Wardrobe Doors section.
1
What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only…
11/10/2023
6
Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as…
8/08/2023
3
Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the…
