Browse Forums Building A New House 1 Aug 24, 2010 4:31 pm Hi all, We are planning to build the Francis 29 . One of our estate covenants is the requirement for a 22 degree roof pitch. To facilitate this Porter Davis is charging us 1477$ to upgrade from the 20 degree roof pitch which comes with the default Alendale facade. We saw the plan for a Westleigh facade for the Francis, which by default comes with a 22.5 degree pitch. But after inquiring with Porter Davis they say its a typo. Has anyone got any information on this or have been through a similar ordeal? Tarneit : The Reserve Re: Porter Davis Facade for Francis 2Sep 03, 2010 4:32 pm rramesh Hi all, We are planning to build the Francis 29 . One of our estate covenants is the requirement for a 22 degree roof pitch. To facilitate this Porter Davis is charging us 1477$ to upgrade from the 20 degree roof pitch which comes with the default Alendale facade. We saw the plan for a Westleigh facade for the Francis, which by default comes with a 22.5 degree pitch. But after inquiring with Porter Davis they say its a typo. Has anyone got any information on this or have been through a similar ordeal? Hi rramesh, I've had a look into your question about roof pitches. Unfortunately it is correct that there was a typo on the Westleigh facade. All the facade options available for the Francis have a roof pitch of 20 degrees. Because of your estate covenants, you will need to upgrade your facade to match the 22 degree roof pitch requirement. With your facade options, have a chat to your CSC or even your sales consultant. They'll be able to help you out. I hope this clarifies things for you! Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis Facade for Francis 3Sep 03, 2010 6:02 pm My home had a standard 22 degree roof pitch that I increased to 25 degrees. My concern is not style but to ensure that water comes off the roof as quickly as possible. I have also been led to believe that the lower the pitch the greater the possibility that water will push thru the tiles in strong winds??????????????? Not a criticism of different builders options. Just a question??????????????????????? Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12340 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4212 |
