Browse Forums Building A New House 1 Aug 24, 2010 11:33 am Hi Guys, We have been in our house for nearly a year now, and we have noticed (yes, i know it took us a while cause they were working fine so didnt think anything of it) that what was meant to be IXL Tastic's installed in the ensuite and main bathroom, they have actually put in a cheaper brand even though we have been chraged for the IXL's. Do you think its too late to speak to the builders about getting the right ones put in or a refund? Thanks Building Our First Home! PCI Date - 28/08/09!!!!! HANDOVER - 4th SEPTEMBER!!!!!! Re: Paid for, but received different ones.... 2Aug 24, 2010 11:44 am I think if you have paid for it then you have to get it. not your fault. Put your foot down.lol Forrester 43sq We have our keys (3/6/11) Now it's time to decorate (that's the fun part.lol) https://forum.homeone.com.au/viewtopic.php?f=31&t=37598 Re: Paid for, but received different ones.... 6Aug 25, 2010 10:42 am you don't know till you ask! they might try to use the fact that you've used it for nearly a year as an excuse not to replace them, if so think about whether you'd accept a cash refund for the difference in cost between the expensive IXLs and this one as an acceptable fix? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Paid for, but received different ones.... 7Aug 25, 2010 11:53 am Ames84 Thanks guys for the replys..... Do you think that the time frame will be an issue? Shouldn't be an issue - just think about your approach. If you come in aggressive they'll definitely put their guard up. Explain the situation, and have two potential outcomes in mind (replacement or a credit back to you), builder can then discuss best option. Keep in mind, if you get the credit, you'll be given the difference most likely - not the full amount. Not sure if you are happy with that, and most importantly - can you live with that? yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5222 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6200 Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 10845 |
