Browse Forums Building A New House 1 Aug 21, 2010 7:08 am Is it normal to have gap like this between bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Such gaps are almost there on all sides of the house, mostly below the left hand side of the windows. Please do tell me if this is something that i need to talk to my site supervisor? Is there a reason why they leave such gap or is it a bad job done by the brick layers? Re: Is it normal to have gap like this between the bricks??? 2Aug 21, 2010 7:43 am they are expansion joints. they are put there to stop the brick wall from cracking through movement of the earth etc. they will come along later and put some foam in and then silicone over it in a colour similar to your bricks. quite normal, don't worry google brick expansion joints. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Is it normal to have gap like this between the bricks??? 4Aug 22, 2010 9:57 am They should be marked on your plan as AJ (articulation joint) 2 7540 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4878 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19256 |
