Browse Forums Building A New House 1 Aug 19, 2010 11:23 am Hi, I have a land with slope fall 1000mm from left to right in Victoria. Initalliy I spoke to Carlislie Homes and the sales consultant said they can build on it as long as the fall doesn't exceed 2.5 meters. And later when they checked the land, they said they can't build on it and most builders are not able to build on it either. My land is in an established middle suburb in Melboure. There are a lot of new homes currently in building in my area with same of slope size. Is slope with 1000mm fall a big issue with most builders? Can someone recommend a quality builder who can build on this kind of slope? Thanks Heaps Re: New Building on a slope of 1000mm fall 3Aug 19, 2010 12:12 pm We are a knock down/re build. Corner to corner we were measured as fall of 1 metre (1,000mm). That is a very flat block. In fact our builder is having to redesign the storm water pipes to get adequate flow off the block (too flat). Re: New Building on a slope of 1000mm fall 5Aug 19, 2010 2:23 pm can you post your site survey? or anything which might give us some dimensions of your block.. My block slopes from front to back, and we have done split level 500mm at garage and 500mm at kitchen.. So a total of 1000mm over the building block. Left to right does sound a little more tricky, but still possible. Re: New Building on a slope of 1000mm fall 6Aug 19, 2010 2:36 pm 1m fall? Why on earth can't they build on it? I built with PD, and around me are M'con, Simonds, DFH, JG King, Hotondo, Henley and NBG... and we all have similar fall. Around 3m over the block, around 2m across the house, and the fall is left to right. Most of the big builders will build on your block if the fall is the only issue. That's the thing.... are there other issues? Easements, excess fill, no room for retaining walls due to the size of the house on the block? I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: New Building on a slope of 1000mm fall 7Aug 19, 2010 3:08 pm Agree with Joles. 1 metre is easy. A little site cut on one side is all. Perhaps a 400 - 600mm (2-3 sleepers) high retainer wall and all good. There's another story here they haven't told you about. Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: New Building on a slope of 1000mm fall 8Aug 19, 2010 3:19 pm check out the link below, this is my land, there is a weatherboard house on it. I am going to knock it down and then build. there is a sewage/drainage reserve on the second block next to it, I assume maybe this is the only reason???? or maybe Carlisle is too busy, and they won't bother to build on this????? http://maps.google.com.au/maps?f=q&sour ... 1,,0,10.33 Re: New Building on a slope of 1000mm fall 9Aug 19, 2010 3:52 pm Looking at the contour map of the property, there looks to be not only a 1m fall from side to side but a big change from front to rear as well - maybe 4 metres. I don't know if this is still the same now but when it was originally surveyed this is what was listed. If Carlisle didn't view it personally but went off the maps, they may have been scared off by this. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: New Building on a slope of 1000mm fall 11Aug 19, 2010 4:30 pm Land & fall is so tricky. We bought a block, based on the fact it was 'flat' to the naked eye. I knew it had a slight fall, but figured it would be with the 300mm that's allowed by most builders. Turns out we actually have 800mm fall across the building envelope alone, and site costs of about $25k given the silty clay soil. To think that I thought I did my due dilligence! I can see how people get caught out with building costs. I would look into split level - might lessen your site costs. I think I saw AV Jennings is doing split level homes now??? Some others too I think. Amazing_Venice [size=50]Signed: 31/07/10 Colour Appointment: 08/09/10 Deposit Tender 20 / 09 / 2010 Final Contract Signed 18 / 11 / 2010 Slab laid 02 / 2 / 2011 Frame completed 25 / 02 / 2011 viewtopic.php?f=31&t=37417&p=553032&hilit=oxford#p553032 Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4682 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18384 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1609 |
