Browse Forums Building A New House 1 Aug 17, 2010 8:40 pm I have plans for a pool cabanna which is 42m2 with a pitched colourbond roof and colourbond walls and sliding doors at the front. what should it cost? I also need a timber deck built that is 81m2 and built on steel posts, in some places the deck will be 3m high? And i wanted to use mahogony (blonde timber 134 x 90mm boards). ANy ideas on the cost? I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20427 DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 13038 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9246 |
