Browse Forums Building A New House Re: Hot Water Unit Base 2Aug 18, 2010 12:59 pm If I was to win Lotto, I would build with a different builder, now to win lotto Re: Hot Water Unit Base 7Aug 18, 2010 5:48 pm Hi I have this problem too, only difference is a concrete slab was poured for it and for some reason the plumbers saw fit to sit a concrete tile on bricks instead. I have been told this will be rectified when they come to install my water tanks. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13748 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20228 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
